Air-con gone
Post your Cit/Peu/Ren air conditioning queries or advice.
x 1481
Re: Air-con gone
Unread post by xantia_v6 »
There were more than one type of compressor fitted to Xantias. I think that one model had a tendency to leak at the joint between the 2 halves of the compressor body, if this is the problem with yours, then it might be time for a new compressor.
harryp
(Donor 2022)
x 75
Re: Air-con gone
Unread post by harryp »
Thank you V6 :) , or is it :cry: ??
I wonder if anyone knows as to which type leaks between the halves. Mine is Nov 2000 manufacture. Could have another go and see if I can read off the numbers if that will throw any light on it. Any one any more info?? Will any late model compressor fit? Thanks.....
Regards
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
