synergie diesel hard work to start - bubbles fuel line
Xantidote
x 5
Re: synergie diesel hard work to start - bubbles fuel line
Unread post by Xantidote »
Harlequin wrote:hmmm will take them out tommorrow
No, not suggesting you take them out, which I'm guessing is a bit of a pain. Was thinking initially of just checking that you've got voltage on the busbar when you operate the key to switch the glowplugs on. This would at least indicate the glowplugs' relay is working. Assuming it is, you might then consider checking a couple of the glowplugs individually. if you've 2 glowplugs functionong, then I'd expect it in the warmer months to churn and cough, and finally burst into life. You shouldn't have use Easy Start all the time. Was going to ask if you have fuel at the injectors, but of course yes, or it wouldn't fire up with the Easy Start.
Martin
Harlequin
x 24
Unread post by Harlequin »
white clouds of unburnt diesel on crank over.
will check tomorrow if I need to use the manual primer. even so , I'm thinking now it maybe electrical
x 1485
If it's smoking on cranking then it's not an air leak problem. It's either the plugs, the valve clearances, or the timing. If it's done 150k+ then my money would be on the valves....
Harlequin
x 24
its only just gone over 100k - I`ll be taking the plugs out next , and if they are shot (again) then replace the timing circuit
x 5672
Check the relay for the glowplugs.
Son's 306 had similar symptoms and it was just corrosion on the connector to the relay.
Bit of a cleanup and it was fine again.
Harlequin
x 24
which relay? the box on its own or one in the fuse box ?
x 5672
It was the box on it's own, fixed to the battery panel.
Harlequin
x 24
otherside of the engine bay on mine - disconnected it , liberal use of wet and dry and electric cleaner spray and it appears to be back to isnant starting!
thank you!
Xantidote
x 5
That's good news :-D
Hope your starting problems are now all fixed!
Martin
