Yes, don't they justSkull wrote:Cheers CitroJim they cost a fortune for what they are
- x 8422
Re: I have become an Activa owner...Project Stictiva-V6
- x 1997
Going to try LEDs into these, I really cannot be ar3d going in there again
edit:
is this them
http://www.phoenixautobulbs.co.uk/sc/pc ... bulbs-12v/
edit:
is this them
- x 1997
Wheels (from donor) refurbished....the original ones (same type/style) are now off getting a higher grade powder coating.
Getting very excited by the handling of this car, I am enjoying its poise and predictability but think I will swap off the Continentals and go back to Michelin Pilots as they have a stiffer side wall and suit the SC.CAR system better reportedly, any comments on that guys ?.
- x 8422
Wheels look lovely Alasdair
- x 1997
Tank you Jim,
Like new trainers,,,,,,they look very bright at the moment.
Skull
- (Donor 2026)
- x 382
That Activa looks great in your photos StickyFingers
Hopefully see it in the flesh sometime
Gary
Gary
OnlineHell Razor5543
- x 3296
That light bulb does look like the ones I popped into Gracies heater control panel.
chinkostu
- x 30
Looking great Al
You've convinced me on the clear indicators too, don't think they ever fitted them to an S1!
As far as tyres go you want a stiff sidewall for handling, but at the compromise of ride quality!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- x 8422
No, they weren't but can be retrofitted easily. The S2 clear ones are identical and swap straight over. My S1 Activa has them.chinkostu wrote: You've convinced me on the clear indicators too, don't think they ever fitted them to an S1!
- x 1997
I did not know that.....I just thought mine were as it came....now, should I switch back for "originality" ?
- x 8422
No, clear ones look nicer in my opinion Alasdair... Cleaner...
elma
- x 284
If you haven't already ordered LEDs be cautious. I stuck them in the instruments and switches of my van, then had to change back because they didn't illuminate the entire dials.
Love the wheels and my votes on smokey S1 rear lights with smokey side indicators if they are available.
Stiffer tyres always in a car you want to throw around, increasing the load and speed rating beyond what is specified works for me. I buy V rated rather than H for my Xantia as I prefer the feel and the suspension has plenty of cushioning anyway. I'm annoyed about that actually my favourites on a Xantia are 195/50/15 92V, which is no longer available in any brand I can find.
DHallworth
- x 161
Those wheels look gorgeous.
My Activa wheels still look like new, they've got a cracking shine to them still but they're just starting to corrode around the valves so I'll need to get them done at some point.
Still trying to decide if I should have mine resprayed to make it factory fresh or just leave it and drive it then when it's peppered in chips have it done.
Looks great from a distance but up close it annoys me!
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 1997
Thanks chaps.....I did these wheels myself, the good ones as said are off for full "service" and will be powder coated to the correct colour....?? Any one know what the colour code is for Activa wheels ?
I had paint breakdown in various places however mainly in small areas only where there had been damage. The original passive coating under the paint was all OK , about three layers, one black ! so I removed this mainly with a heat gun and home made wooden chisels and scrapers. Some flap wheel work with the Dremel, filler and a good hand sanding. Some slight kerb damage was built up with metal filler.
I used an epoxy primer then silver paint I use for radiators when creating a "polished" look....some Poxhall shade, I buy the base and mix. I topped it with clear with added talc to give a silk finish. I protected it with solid wax then a finishing gel polish
chinkostu
- x 30
Nah clear ones take years off the car, as well as the mirror caps. My SX with ambers and black mirrors looks as old as it isCitroJim wrote:No, they weren't but can be retrofitted easily. The S2 clear ones are identical and swap straight over. My S1 Activa has them.chinkostu wrote: You've convinced me on the clear indicators too, don't think they ever fitted them to an S1!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
