Xantia Injection Fuse blowing
superloopy
x 19
Re: Xantia Injection Fuse blowing
Unread post by superloopy »
xantia_v6 wrote:The Activa is a TCT with the extra anti-roll suspension components, the engine and electrics should be identical.
In RHD, all TCT hatchbacks were I think Activas, and all TCT estates were just TCTs.
I concur [emoji1]
Sent from my LG-D855 using Tapatalk
Mike
soufle
x 5
Unread post by soufle »
thankyou : ) if I can this little beast to behave I am going to love it. Still rebuilding a 74 DSpecial which I also am looking forward to driving soonish! Thanks for the input everyone, great website!
x 8210
Mine has a 25A fuse for F7 :roll:
superloopy
x 19
What year is yours Jim?
Mike
x 8210
1996 Mike...
soufle
x 5
well I bunged the front end back on (that was fun getting the side bolts back in on on the bumper NOT!) ignored the myriad of other issues my £150 supercar had and took it home from the car club about 15km with it's new 25Afuse. Went a treat with a guzzle of 95 in it, drives quite nicely.
The code start up is a tad annoying, it's not exactly being put to James Bond usage.
thanks for the advice, the owners manual ruined the experience for the prvious owner, printed in late 96, definitely the F7 fuse is listed as a 5A. Weird?
cheers Steven
x 8210
Excellent :) So all is now good?
x 1982
Unread post by Stickyfinger »
Code input is an easy bypass......if you want to
x 8210
Stickyfinger wrote:Code input is an easy bypass......if you want to
Not on a TCT it isn't :( The only ECU that does not respond to the 'normal' trick.. The TCT must therefore have a keypad...
Unless you pay megabucks to a clever sod to have the ECU unlocked in a different way...
x 1982
It has worked on my Donor car.....is that not a TCT then ?
x 8210
Stickyfinger wrote:It has worked on my Donor car.....is that not a TCT then ?
Yes, it is... Now that is VERY interesting Alasdair... First one I've known... Normally they don't play nicely at all...
x 1982
I took it off the other day as I both wanted a good one (worn button) and it was a pain starting it as it is left next door and she may wish to move it (garage door protection) at some stage.
It starts fine without, I had the other one ready but it did not need it.....have a look when your next down.
x 8210
Stickyfinger wrote:have a look when your next down.
I will, I'll be interested in comparing ECU part numbers...
Forgot to say in the PM I sent Alasdair, I finally retrieved that lost V6 Hydraulic Pump nut today from the donor :-D :-D :-D
x 1982
....I had to make a long rod (tomato plant stick) with a magnet hot glued on it (you know the one), to retrieve a bolt the other day from a worrying postion ......the bolt jumped UP to the magnet :)
x 8210
Those magnets are magical Alasdair :-D Saved me a lot of grief....
