rear arm bearings fitting advice needed
darbuck
x 289
Unread post by darbuck »
How are you doing lads looking for some advice on rear arm bearing fitting i cant get the plastic spacer tubes to fit into the arms.All other parts are fine for fitment.
Darren
rory_perrett
Re: rear arm bearings fitting advice needed
Unread post by rory_perrett »
By not fit what do you mean? Too long or too big a diameter?
x 2008
Unread post by Stickyfinger »
2003 2.0 HDI ESTATE C5 this one ?....put it in your Sig mate :)
x 1481
Unread post by xantia_v6 »
Are you sure that the kit is the right one for your car?
darbuck
x 289
hi lads thanks for reply couldnt reply before this as laptop decided it wanted a reinstall of windows .anyway to answer all questions just the spacer outer diameter is too big.i got kit from eurocarcare so i presume its correct everything fits except as sticy has corrected my definition :lol: the rear seal protector.
Darren
Lighty
x 34
Unread post by Lighty »
Not wishing to criticise their kits, but pretty sure one of my customers bought his own kit to me a few months ago & his rear seal protector :) ( plastic tube) wouldn't fit either.
This was from Eurocarcare
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
darbuck
x 289
i ended up grinding seal protector diameter down on the bench worked a treat all back together and moving lovely.
Darren
x 2008
nice not to have the clack clack and people looking at you :)
