DHallworth
x 162
Re: I have become an Activa owner...Project Stictiva-V6
Unread post by DHallworth »
Mine does exactly the same Sticky. It's got a brand new, genuine thermostat in it that I fitted during the conversion as well.
Here's where mine was sitting after around 200 miles on the way back from the Northern.
I was a bit worried about it before and started a thread about it last year when I was assured it was normal as well.
http://www.frenchcarforum.co.uk/forum/v ... 70#p420406" onclick="window.open(this.href);return false;
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 2003
Unread post by Stickyfinger »
SNAP ! ...100%
I have also just found a French invoice/payment for a new water pump, two pipes, anti-freeze and a thermostat put on in Nov 2013 by a local Citroen specialist.....so that's good :)
?? how did you afford half a tank ? and why does the search function work so badly :)
DHallworth
x 162
That was it's 2nd tank in one weekend :lol:
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
chinkostu
x 30
Unread post by chinkostu »
DHallworth wrote:That was it's 2nd tank in one weekend :lol:
Even the dervs can be uneconomical if you mess with them. :wink:
I filled mine after messing with the fuelling and it soon drank it :shock:
although I think it would still be better than the v6 :rofl2:
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
DHallworth
x 162
From home to Scotch Corner on the way to the Northern was a distance of 179 miles 130 of which are motorway (M8, M74, M6), by the time I joined the average camera on the A1 just south of Scotch Corner I was nearing 1/4 tank left.
Penrith to Scotch Corner was where I used most of it as there was a guy in a Mercedes that got a bit of a shock when he went for the overtake on a corner. :lol:
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 3298
V6 Xantia Activa; used for extreme speed ironing of bumpy corners!
x 8423
Hell Razor5543 wrote:V6 Xantia Activa; used for extreme speed ironing of bumpy corners!
It does a fine job of ironing bumpy roads in general James :-D
x 2003
Jim, you were (as always) correct about the cabin filter.....and the thought of using the V6 one as a temporary filter is out as well :)
x 8423
Gosh, France must be mucky! Better in the filter than your lungs :wink:
x 2003
Some details for reference
Heater control Lamp holders/Sub-Unit vrs Dash Lamp holder....note it is the mount and NOT the bulb which differs. WRONG...see below
The bulbs are soldered into the mount and then applied....I see no reason not to just bridge the earth/power strips with your LED of choice here.
x 8423
Sticky, you'll also find the bulbs themselves have to be shorter to fit... Normal dash bulbs won't work :twisted:
Why the heater uses very slightly different bulbs is one of those mysteries that will be forever unresolved...
Skull
(Donor 2026)
x 382
Unread post by Skull »
£3.54 bulb (ventilation panel / illumination) (611260)
I believe as Citrojim that it's a shorter bulb to allow in-situ fitment rather than removing the units control cables :?:
MIGHT NOT be necessary if the unit is already removed for fitting :?:
Gary
x 8423
Skull wrote: MIGHT NOT be necessary if the unit is already removed for fitting :?:
Yes it is as the longer (instrument) blubs will foul the mechanism..
If you needs some I can bring some along on Wednesday. I have some here...
x 2003
Well I just took a bulb out....that will teach me.....retract !
15mm & 18mm
Skull
(Donor 2026)
x 382
Cheers CitroJim they cost a fortune for what they are :?
Gary
