How to get my ABS unit specs
Alshahawy
Unread post by Alshahawy »
Hi all,
How to know if my ABS unit has an EBD Breaking System?
I used my VIN at http://www.peugeot-planet.com/ to get my car specs and I didn't find indication that it has an EBD, it just says:
"BRAKE ASSOCIATED VARIANT ABS TEVES MK100A"
What is TEVES MK100A? Is it the brand of the ABS unit used in my car? And if yes, how to contact the manufacturer to get all the specs of the ABS unit?
I tried searching in Google in vain.
Thank you in advance.
elma
x 284
Re: How to get my ABS unit specs
Unread post by elma »
Teves abs mk100a is the make and model of your abs ECU.
I'm no expert but they also make an "esp mk100a" which I believe is the version with ebd.
Alshahawy
Thank you elma, so how can I get my ABS unit model and manufacturer to get the ABS specs and whether it has an EBD or not?
Alshahawy
This is my car build code, can it be used via online service to get the info I need about the ABS unit?
Build code 13588 FV 1 0356
elma
x 284
What is your car?
Alshahawy
Peugeot 301 Allure
Alshahawy
This question is very important and I really need to find a way to confirm my ABS unit specs and whether it has an EBD or not ... Thank you
x 1461
Unread post by xantia_v6 »
The Peugeot 301 is not sold in western Europe, and not at all in the UK, so there are not many people on this forum who are familiar with them.
I can only suggest that you ask a local dealer, or the Peugeot importer in your country.
Alshahawy
Thank you xantia_v6 for your reply & suggestion, it's really appreciated.
For sorry I couldn't get an answer from our local dealer - and so the other customers - about whether the car ABS unit has an EBD or not. So how could you find an answer to such question in general regardless of the car model? I got all my car specs via link provided above and there is no mention to the EBD, so what does this mean?
x 5672
You could try opening an account at Service Citroen -> http://service.citroen.com/pages/index.jsp" onclick="window.open(this.href);return false; and looking your car details up - you will need the VIN and RP to pin it down.
ETA: Ooops :oops: Perhaps Service Peugeot would be more helpful -> http://public.servicebox.peugeot.com/pages/index.jsp" onclick="window.open(this.href);return false;
Alshahawy
Thank you myglaren for your suggestion, it's really appreciated.
I already have an account at http://public.servicebox.peugeot.com and using my VIN I only got the info below (in the images), is there a section under Peugeot service box where I can find the ABS unit specs?
These are the info I got using my VIN at Peugeot Service Box
Vehicle characteristics
Vehicle family 301
Warranty Start Date 01/03/2014
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY 301
SILHOUETTE 4 DOOR SALOON
TRIM LEVEL MEDIUM HIGH
ENGINE EC5 INJECTION
TRANSMISSION BVA4
PAINT TYPE METALLIC LACQUER PAINT
BODY COLOUR KGQ - KYANOS BLUE PAINT
INTERIOR TRIM TYPE WARP AND WEFT OZA + PLAIN SERGE "8W"
UPHOLSTERY COLOUR "FX"
GEARBOX (CHARACTERISTICS) AUTOMATIC GEARBOX AT8
ENGINE (TYPE) EC TYPE ENGINE
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE WITHOUT BADGE
SPEEDOMETER DRIVE SPEEDOMETER RATIO 21 X NO
Fuel supply-Engine
FUEL SUPPLY INJECTION
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL RON 95 PETROL GRADE A/B/E/E+
EMISSIONS STANDARD (ENGINE) EURO5 EMISSION CONTROL (ENGINE)
SPEED SENSOR SIGNAL WITHOUT SPEED SENSOR
CATALYTIC CONVERTER 2-COMPOUND CATALYTIC CONVERTER UPPER FILTER 50PPM 40 GR
OIL COOLER OIL COOLING UNIT
LPG FUEL TANK FUEL TANK WITHOUT LOCATING TAB
COOLING MOTOR RADIATOR TH : 27 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING WITH SUMP GAS CIRCUIT REHEATING
EOBD SELF-DIAGNOSIS SYSTEM WITHOUT "EOBD" AUTO-DIAGNOSTIC
DEVICE (ANTIPOLLUTION) WITHOUT ANTI-POLLUTION DEVICE
VEHICLE TECHNICAL DEPOLLUTION K PRIM VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTER WITHOUT PARTICLE FILTER
FAN 1 AERO 2-SPEED 140W FAN WITHOUT SCOOP
FUEL VAPOUR RETRIEVAL CONTROLLED PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT VALEO INJECTION SYSTEM
TANK FILTER RESERVOIR FILTER EXTERIOR
STOP AND START WITHOUT STOP AND START
Gearbox Transmission
TRANSMISSION BVA4
FINAL DRIVE RATIO AXLE RATIO 20 X 73
WHEEL STYLE WHEEL RIM ALLOY SPA 16"
DIFFERENTIAL (GEARBOX) 84 DIAMETER DIFFERENTIAL
RIM/TYRE SIZE 16 INCH TYRE FITMENT
TYRE (SIZE, TYPE) 195/55 R16 T NON-REINFORCED TYRE
WHEELS FITTED 6" RIM ROAD WHEELS
WHEEL (TYPE) ALLOY WHEELS
GEARBOX TYPE AUTOMATIC GEARBOX AT8
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAMETER 20.5
SERVICE BOX
Documentation Backup
301 4 DOOR SALOON 1.6 VTi 16V 115 (EC5) BVA4
BRAKE TYPE FRONT VENTILATED DISCS/REAR DRUMS
SUSPENSION NORMAL HEIGHT ADJUSTABLE SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
STEERING (OPERATION) ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE) SIMPLE STANDARD PEDAL BRACKET
Body fittings
TOWBAR WITHOUT TOWBAR
AERIAL SHORT ROOF AERIAL
FINISHER (SELF-ADHESIVE) REAR TRIM FR DOOR+REAR DOOR BLACK MATT
WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL CAP
UNDERBODY SHIELD METAL PROTECTOR UNDER ENGINE
ADDITIONAL SHIELD (UNDER ENGINE) ENGINE UNDERSHELDING
EXT. LOAD RETENTION RING (ATTACHMENT) WITH DETACHABLE EXTERIOR LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTION MANUAL FOLD EXTERIOR MIRROR
EXHAUST TAILPIPE TRIM W/O EXHAUST OUTLET EMBELLISHER
WINDSCREEN GLASS (TYPE) STANDARD WINDSCREEN GLASS
WINDSCREEN WIPER 2-SPEED INTERMITTENT WINDSCREEN WIPE WITHOUT WATER
LEVEL INDICATOR
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
OUTSIDE TEMPERATURE SENSOR WITH EXTERNAL TEMPERATURE SENSOR
BUMPER BODY COLOUR STANDARD FRONT/REAR BUMPER
MUDFLAP WITHOUT MUD FLAPS
FRONT FOGLAMP WITH FRONT FOG LAMP
EXTERIOR REAR VIEW MIRROR (DRIVER
SIDE)
DRIVER’S DOOR ELECTRIC MIRROR
EXTERIOR REAR VIEW MIRROR (PASSENGER
SIDE)
PASSENGER ELECTRIC DOOR MIRROR
SPARE WHEEL SPACE SAVER WHEEL+NON STANDARD TYRE
EXTERIOR ACCESSORIES BODY-COLOURED EXTERIOR HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE
RADIUS)
CURVED EXTERIOR MIRROR GLASS
BUMPER TRIM CHROME INSERT ON FRONT BUMPER
REAR WINDOW (TYPE) REAR GLASS HEATED
GLASS (APPEARANCE) WINDOW TINTED
WINDOW (TYPE) LAMINATED WINDSCREEN + SIDE WINDOW AND REAR TOUGHENED
Interior fittings
SIDE ARMREST (TYPE) LATERAL ARMREST WITH ENDCAP
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTER WITH FRONT LIGHTER
REAR SEAT SEPARATE FOLD BACK BENCH SEAT
REAR SEATBELT 3-REEL, 3-POINT REAR SEAT BELTS
FRONT SEATBELT PYROTECHNIC SEAT BELT WITH ALARM
ASHTRAY FRONT ASHTRY
CLIMATE (AMBIENT TEMP) HOT OR WIDER TEMPERATE COUNTRY
AIR CONDITIONING AIRCON WITH MOTORISED AIR INLET
SPEED GRADUATIONS SPEED GRADUATION IN KM/H
GRAB HANDLES REAR HANDLES WITHOUT HOOKS
RADIO EQUIPMENT FEED AERIAL RECEIVER FRONT/REAR SPEAKERS
DRIVING POSITION LEFT-HAND DRIVE
REMOTE CONTROL WITH REMOTE CONTROL
BOOT AND LOAD SPACE LIGHTING LOAD VOLUME + BOOT LIGHTING AUTO CONTROL
DASHBOARD EQUIPMENT PEUGEOT ALLURE DECOR
MISC. INT. LAMPS FRONT SPOTLAMP
LOAD SPACE TRIM BOOT CARPET + CARPET SIDES
INSTRUMENT PANEL (CHARACTERISTICS) GRADATION 220KM/H 135M/H BLACK BACKGROUND CHROME
CIRCLE
DOOR TRIM CLOTH DECOR
CHILD SEAT ANCHORING POINTS CHILD SEATS WITH ISOFIX ANCHORAGES
LOUDSPEAKER 2 FR SPEAKERS+2 RR SPEAKERS
RADIO CONTROLS 2 FRONT SPEAKERS
POLLEN FILTER WITH POLLEN FILTER
FRONT SEAT ARMREST FRONT SEAT CENTRAL ARMREST
REAR WINDOW LIFT REAR ELECTRIC WINDOW + LOCKING
DRIVER’S WINDOW LIFT STANDARD ELECTRIC DRIVER’S FR WINDOW
PASSENGER’S WINDOW LIFT STD ELEC CONTROL FRONT PASSENGER ELECTRIC WINDOW
DISPLAY MONOCHROME SCREEN LEVEL C DISPLAY
COURTESY MIRROR PASSENGER SIDE WITHOUT LIGHTING
OIL GAUGE WITHOUT OIL LEVEL GAUGE
FITTING REAR HEAD RESTRAINT WITHOUT REAR HEAD-REST
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG WITHOUT SIDE AIRBAG
PASSENGER AIRBAG WITH AIRBAG ON PASSENGER SIDE
ON-BOARD COMPUTER COMPUTER
EXTERIOR REAR VIEW MIRROR (HEATED) UNHEATED EXTERIOR MIRROR
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE) CHROME FINISH INSIDE DOOR HANDLE
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SUN VISOR DRIVER + PASSENGER SUN VISOR WITHOUT INSCRIPTION
STORAGE (DRIVING POSITION) LOWER ODDMENTS TRAY WITH FLAP
RADIO RECEIVER RADIO RECEIVER RD45 MP3 RADIO CD, SEPARATE DISPLAY
REFRIGERATION IMPROVED AIR CONDITIONING
CRUISE CONTROL WITHOUT CRUISE CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
STORAGE (OTHERS) PLAIN STORAGE POCKET
DRIVER AIRBAG DRIVERS AIR BAG
RADIUS)
TUNER RADIO MONO RADIO TUNER
EXTERIOR TEMPERATURE (SCALE) CELSIUS EXTERIOR TEMPERATURE INDICATOR
OBSTACLE DETECTION SYSTEM REAR RADAR OBSTACLE SENSOR
TRIM ADAPTATION WITHOUT MOULDING ADAPTATION
LOCKING CONTROL NORMAL + AUTOMATIC LOCKING
STEERING WHEEL LEATHER 3-SPOKE ST WHL WITH DECOR+
AUDIO PACK AUXILIARY SOCKET WITH 1 JACK SOCKET + USB
Electrical
ALTERNATOR ALTERNATOR 120 AMP
BATTERY BATTERY L2 640 EN
STARTER MOTOR STARTER MOTOR CL 3
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
CEN. LOCKING REM CONTROL FREQUENCY LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ
HETERODYNE
RADIO FREQUENCY ASIA RADIO FREQUENCY
TELEMATIC UNIT WITHOUT TELEMATIC UNIT
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS DUSTY ATMOSPHERE
VIN PLATE OUTSIDE EUROPEAN UNION CONSTRUCTOR’S PLATE
RADIO HEADPHONE SOCKET WITHOUT ACCESSORIES SOCKET
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 1 HIGH FREQUENCY REMOTE CONTROL KEY+1 MAIN KEY ONLY
REFRIGERANT REFRIGERANT LIQUID R134
EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
SURFACE CONDITIONS UNEVEN TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
ADDITIONAL TYPE APPROVAL PLATE W/O ADDIT HOMOLOGATION PLATE
SLAVE CONTROL UNIT BSI + COM 2005
x 5672
I am personally not familiar with Service Citroen/ Servicebox. Our late member citronut was the go-to guy for that and could find practically anything. Your list is a bit short on detail regarding the braking system.
The only thing I have been able to come up with is this description: http://www.aa1car.com/library/abs_teves_mk20.htm" onclick="window.open(this.href);return false;
Can't say if that would be helpful or not.
x 1995
Unread post by Stickyfinger »
Alshahawy
Thank you so much Stickyfinger, I believe I'm getting closer to find the answer; I belive http://www.conti-online.com" onclick="window.open(this.href);return false; is the manufacturer of my car ABS unit, but I couldn't find an email to contact them, and there were no specs for the MK100 (A,B,C,D) series.
Alshahawy
I just found their page on Google+ (https://plus.google.com/+ContinentalCorporation/about" onclick="window.open(this.href);return false;) and send them a message on Their Facebook account, I hope to get an answer from them soon, I can't thank you all enough.
