https://goo.gl/photos/jy3GrY9XQ1ESsjYU8" onclick="window.open(this.href);return false;
trying to repair binding brakes on the rear, the cylinder is leaking so im going to replace with a full brake kit from eurocarparts for £50
could someone please advise what system i have as dont want to be ordering the wrong item.
i presume because non abs its 180mm diam and a bendix system
this is the ecp relacement http://www.eurocarparts.com/ecp/c/Peuge ... 859&000419" onclick="window.open(this.href);return false;
regards
rear brake drum type?
- x 5672
Re: rear brake drum type?
If you post your VIN and RP numbers someone will look your car up and let you know what it came with from the factory.
creon
vin:- VF3**************[VIN obfuscated, can be read by forum staff]
its a dw8 on 99 plate, measuring the drum its 203mm but why the variations
i think its a lucas system 203mm with teves front disk system but says bendix on brake fluid res, id hate to be wrong.
where this might be the part but says for cars with abs http://www.eurocarparts.com/ecp/c/Peuge ... 2b9&000419" onclick="window.open(this.href);return false;
creon
after digging about ive come to the conclusion its a girling drum set up with 203mm drum and bosch 4 wheel abs, lets hope ive ordered the correct parts.
chinkostu
- x 30
Servicebox agrees with you.
I've always had issues with PAS drums, quite a few variants and weve had the wrong ones many times
It is also listed as having abs
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
creon
job is now on hold, ill have to take it to the garage as the brake union into the cylinder is welded with rust! PITA
- x 1995
heat it, one of those Kitchen mini blowlamps .....they work well
- x 1490
Chances are the other end of the pipe will be OK, so best just to sacrifice it, and get a new one made up - std flare so should be easy to get hold of. Even if you get the union going, it's probably welded to the pipe, and you will end up mashing the nut as you try and get it out (and back in).
