boing/click when moving steering 'back from' n/s full lock
dei9
Unread post by dei9 »
Hi,
My car has this boinging noise when I move back from the full lock of the n/s and the n/s wheel. (left side). It's something is catching on something and then gets released when I return the steering. I don't think it's worrying me much, but it's a little weird and annoying tbh. Has anyone come across this before or is it common problem?
Thanks, D
...from Dei
1999 Xantia 2.0 Hdi 110 Exclusive (8396)
2001 Xsara 2.0 Hdi 110 LX Auto
old-un77
Re: boing/click when moving steering 'back from' n/s full lo
Unread post by old-un77 »
off hand, I would guess that its a suspension spring binding, instead of moving/turning smoothly with the steering?? the car IS level? ie not a broken spring?
Bob
dei9
It does sit level and I've checked the springs just now, nothing visibly broken, and it rides ok (very well in fact).
Any other ideas? The MOT is due in August so maybe that will show something unless I can't.
...from Dei
x 1504
It'll be the bearing at the top of the strut probably. Jack it up both sides and wind the steering lock to lock - you will likely find that one (or both!) side goes round in steps rather than smoothly. I had to fit new bearings to our C4 Picasso at 70k - they were well shot!
chinkostu
x 30
Unread post by chinkostu »
Definately top mounts. Both on my 206 were dead, snapped both springs. Get the strut off and a garage can swap them in minutes
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
dei9
Would it cause the steering to pulsate when going round tight corners at low to medium speeds (such as a small roundabout)?
Is the part expensive?
Thanks all, it does sound like that part is worn.
...from Dei
chinkostu
x 30
Not likely, look at driveshafts. Is it knocking on full lock when you're driving?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
dei9
No
...from Dei
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
RichardW wrote:It'll be the bearing at the top of the strut probably. Jack it up both sides and wind the steering lock to lock - you will likely find that one (or both!) side goes round in steps rather than smoothly. I had to fit new bearings to our C4 Picasso at 70k - they were well shot!
Top mount vote here too.. cars dont always sit funny with broken springs..
Jeesus christ and all that Richard your a damm bloody brave man! Ive got those spring compressors and when i nearly killed myself with a 306 spring i vowed never ever to use them again!!!
Leathel things! My local garage now if i take a strut and top mount to them will shove it in a industrial compressor and swap the tops over .. in 10 mins..
A very sad...
1994 XM 2.1 d auto
dei9
Upon closer inspection the spring may be broken towards the top within the shadows, and of course would require the darned top bearing too. Ugh!
...from Dei
citroenxm
Fallen Hero
x 70
Well thats why REAL citroens have hydraulics.. none of this coil spring rubbish lark!!
Crap arent they these peugeots! :rofl2: :-D
A very sad...
1994 XM 2.1 d auto
dei9
Yea, I second that opinion. I had a quick spin in the Xantia the other day, and my god that is better built. I will persevere with it though. It still a fun car. The handling is very very good, the Xantia isn't bad at all for unconventional, but the Xsara glides like it's a rollercoaster (with a broken spring).
...from Dei
dei9
Is that mount broken in two parts? I'm looking for one and they seem to be a one part, is the bearing inside the thing?
...from Dei
chinkostu
x 30
Usually theres a bearing that can be replaced that pops out of the rubber mount. However some cars have them integrated. That mount is however broken into two, the rusty part just above the spring usually sits atop the spring, then the bearing sits between that and the upper rubber part.
If needs be i can look on servicebox and see whats what?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
dei9
That would be cool Chinkostu, so when I take the strut out, do I need to compress the spring before it comes out, or does get compressed afterwards? I've not done this kind of thing before, it can't be hard. I've found access to a spring compressor. From then on it's just nuts and bolts and lining things up isn't it. I'm lookin at one spring first though, unless two is recommended anyway, obviously that costs more.
...from Dei
