Hi I have a tiny leak on my rear suspension gaiter near side, is this a specialists only job or do I go exploring?
If I need a specialist can anyone recommend a decently priced outfit near Walsall West Midlands please.
C5 Mk1 Minor Suspension Fluid Leak
dnsey
- x 19
Re: C5 Mk1 Minor Suspension Fluid Leak
Is the leak from the gaiter, or dripping onto the gaiter from where the vent hose goes into the crossmember?
Garryg163
From the bottom of the gaiter dnsey
dnsey
- x 19
Pity- the gaiter must be split then.
Replacement isn't a specialist job, but removing the pushrod pin and wrestling the new gaiter on can be a bit tricky!
If it's just a nick, you could try degreasing the gaiter and adding a blob of silicone.
waynedance
- x 8
Mine leaks a little from the bottom on the near side. I believe mine is a weak clip, seems to only leak when on high setting and lifted on a 2 post ramp.
I have put a few cable ties on to help seal better.
Sent from my GT-I9505 using Tapatalk
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
Garryg163
Thanks will investigate and report back
