Lexia installation woes....
x 1993
Re: Lexia installation woes....
Unread post by Stickyfinger »
LOL, you know you lost him at Stage 2 don't you :)
The Ace
Unread post by The Ace »
Stickyfinger wrote:LOL, you know you lost him at Stage 2 don't you :)
Now that I re-read my post, yeah probably :-D
However, someone on the same time-zone and availability could Teamviewer-in on his PC and do all these remotely, they are indeed pretty straight-forward for someone with some basic IT skills....you can fiddle with the VM settings, or the WinXP VM environment parameters, but these are tune-up steps and not required for the basic installation.
I just wanted to provide a step-by-step, just to try to give the OP an idea of the required effort....
x 1993
You did mate,
RM206
Unread post by RM206 »
Hi
I am having a bit of a problem with my diagbox install as well. I am running on Windows 7 Ultimate 64bit. I have successfully installed the diagbox/Lexia/PP200 software and (I think) all drivers included on the cd it came with. My problem is that I am getting a "Please connect a VCI" after choosing my vehicle model (Peugeot 206). When I plug the interface into one of the USB ports the light flashes normally (3 flashes etc) but I get no sound nor does anything appear in my device manger, it is as if the computer is not recognizing the box... Is this because of windows 7 64bit or might it be something else ?
Big thanks in advance for any replys !!!
2005 Peugeot 206 1.4L hdi
x 1993
when asked, try switching USB ports. I also boot the PC with the unit in the usb port.
RM206
Tried all of that and no luck, Is it possible the unit might be faulty ?
x 1993
More like its clashing with 64bit Windows....my Windows7 disks came with both 32 and 64 bit disks....I installed 32bit on the LapTop and 64bit on the main box.
x 3302
As Lexia is very old software (16 bit) it cannot run directly within a 64 bit environment. You will need to set up a virtual machine (I cannot advise on how to do this), and then set up a 32bit O/S in the VM, and then install the Lexia software there.
The Ace
RM206 wrote:I am having a bit of a problem with my diagbox install as well. I am running on Windows 7 Ultimate 64bit....Is this because of windows 7 64bit
Most likely...whenever I tried installing on 64bit (7 or 8), the installation failed and/or the app didn't actually work. I then decided to go straight to WinXP, and voila, everything worked flawlesly from the word "go" 8-)
RM206
Ok great. All the installations are fine, diagbox, Lexia, PP2000. It all starts up etc perfectly, it looks like the drivers don't like windows 7, the Diagbox cable isn't appearing on the computer.
Will have a bit of a fiddle and then try a virtualbox with xp.
Thanks !!!
RM206
How about windows 7 32bit ! I have an old computer running that. I will try that first and report back. :D
elma
x 287
Unread post by elma »
That should be OK. Not tried it but planning to soon and my research says win 7 32bit is good for Lexia. Probably.
x 3302
I am using Windows 7 Starter (32 bit), and my Lexia works with it
RM206
Still no luck... installed on 32bit windows and same error "Please connect a VCI"... Might be a faulty box :'( Very frustrating anyhow... It is defiantly the drivers I have. they will not install correctly. If anyone has the working "ACTIAPnP" drivers I would be very grateful
MikeT
x 232
Unread post by MikeT »
These any good? http://www.driverscape.com/download/usb ... stance-%29" onclick="window.open(this.href);return false;
