xsara intermittent electrical faults
dei9
Re: xsara intermittent electrical faults
Unread post by dei9 »
I'll have a look tomorrow, I'll check under the fusebox too? You mean the one in the engine bay? Or the one under my knee? Cheers for the ongoing help.
...from Dei
1999 Xantia 2.0 Hdi 110 Exclusive (8396)
2001 Xsara 2.0 Hdi 110 LX Auto
dei9
Sent from my D6503 using Tapatalk
...from Dei
chinkostu
x 30
Unread post by chinkostu »
Thats vaguely what i was expecting! Can't find it anywhere on servicebox though!
There any part numbers on there? Im thinking its a junction box for stuff
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
dei9
Its definitely a relay with a bit of logic going on. I think it could be to do with the AC stuff now, because that never initiated the fans for some reason. Tomorrow PM I'm going to be going over the fuse boxes and checking continuity wherever I can. Sleepy now.
...from Dei
dei9
Well the relay I fixed is still in one piece and still attached. Problem is still intermittent, even after a battery swap. Where is this earth on the gearbox, I can't see it anywhere? Is it a big one?
...from Dei
chinkostu
x 30
AHA!!!
Thats the Glowplug relay.
https://www.google.co.uk/search?q=glow+ ... 20&bih=920" onclick="window.open(this.href);return false;
i wondered why i couldnt find it anywhere on servicebox.
however, still doesn't point to your issues. hows the car today?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
dei9
Still the same, intermittent, but more off than on. I swapped the battery too, still the same. I wonder if there is a loose connection behind the dashboard and that the gearbox needs to read the speed from there, and because it dies it throws an error in the gearbox?
I've also noticed a three pin plug loose to the left of the fusebox (behind the plastic). I wonder what that is. Engine bay fusebox looked fine, nothing wrong there.
...from Dei
chinkostu
x 30
Is it worth giving the BSI a reset?
http://www.petercoopercarrepairs.co.uk/ ... cedure.htm" onclick="window.open(this.href);return false;
The fact that the dash dies points to something bizzare. There any french specialists nearby?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
dei9
I'll certaibly give that a whirl.
I put the Lecxia on it early this morning. Got the following errors, maybe someone can shed some light on their meanings for me (or location of said components)?:
On the auto ecu:
* Remote/permanent: Injection throttle potentiometer (can)
remote/permanent: auto g/b communication with engine mamagement
* (intermittent) multifunction switch signal intermediate
* (can) engine torque information /coherence
Any clues there?
...from Dei
dei9
Well I followed that guide to the letter. And then I used Lexia to reinitialise the pedal (it seems smoother and less ballistic like, but not slower). It seems to be holding well so far... (watch this space)
...from Dei
dei9
well, I think we can close this one as solved. Three things were done, swapped for a known good battery, a proper bsi reset, and pedal reinitialisation on lexia. It's been fine for days now. Thanks to all that helped.
...from Dei
chinkostu
x 30
Good to hear! Its bad trying to diagnose stuff online as it could be thousands of things!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
dei9
I spoke too soon! It went briefly this afternoon! Sigh!!
...from Dei
dei9
OK... Help... what the hell is it? it went again today, the gearbox went into limp mode, and then the rev/speedo/temp gauge failed, petrol gauge still works. Tried a BSI reset, didn't work. The immobiliser light does what it pleases too. And now it beeps if I leave the of ignition on without starting it. But it still starts. Everything else works fine. Other than an earth or loose a connection do you or anyone have any ideas? Cheers!
...from Dei
x 3567
It's a long shot - but it will only take you 2 minutes. Remove and thoroughly clean the SHUNT fuse. Don't just pull it out and put it back in a few times, but give it a proper clean and also the slot it goes into. I've known a dodgy shunt fuse do funny things with a Xsara dashboard before now.
