Xantia clutch
flying clutchman
- x 3
Re: Xantia clutch
You're very unlikely to need an input shaft tube on T/D as it's a pull type clutch. The bearing is permanently fixed top the cover, unlike a conventional setup anddoesn't rely on the guide tube to,well, guide it. The other two things you mention sound like alternative terminoligy so should be ok.
Xantia97
Re: Xantia clutch
Thanks Clutchman. The citroen garage included the input shaft tube in their quote, but then they also quoted for one diff seal but labour for two!!!
I'll give the input shaft tube a miss then, plenty of other things that money can be spent on
Juliet
Juliet
1997 Xantia 1.9TD LX (owned for 14 years) - Snoopy
Gone but always remembered
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
flying clutchman
- x 3
Re: Xantia clutch
How much labour to change 2xdiff seals? They take literally 2 minutes each once the box is out!
Xantia97
Re: Xantia clutch
They quoted for 20 minutes (so cost would be 13.20 euros) cheeky monkeys! Mind you, I suppose we have to factor in the time it takes them to read the manual so see how to do it
Or more probably they have factored in the time it will take to repeat the procedure when we find they got it wrong
Juliet
Juliet
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
Xantia97
Re: Xantia clutch
So the clutch was replaced yesterday and there is very little improvement in the stiffness of the pedal. Valeo clutch installed (checked with Valeo themselves). The XM clutch is as light as a feather, I was hoping that the Xantia would now be the same. Have to have my left hip replaced but have been told I am too young so have to wait as long as possible (or have the op outside France), so this clutch is a big deal for me to keep the car and of course now I have to push the pedal further than before so it hurts even more
Any ideas of what to try next?
Thanks,
Juliet
Thanks,
Juliet
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
elma
- x 284
Re: Xantia clutch
A worn clutch cable will cause the pedal to be stif, was it changed with the clutch?
Xantia97
Re: Xantia clutch
No the clutch cable was not changed since another garage said the cable was ok but the clutch was definitely on it's last legs.
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
Xantia97
Re: Xantia clutch
Am I expecting too much, should the Xantia clutch be light as a feather? The XM is a hydraulic clutch I think.
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
- x 1470
Re: Xantia clutch
Only the 2.5 XM has a hydralic clutch*, all the others are cable.
* also the ES9 V6, but there are none in the uk
Xantia97
Re: Xantia clutch
The XM is a 2.5TD, RHD.
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
Xantia97
Re: Xantia clutch
Have checked the pedal and the cable was obviously not adjusted for the new clutch, so will be doing that tomorrow.
To remove the air filter housing Haynes says to undo a bolt but I can't see one anywhere, only the clip onto the turbo pipe, is this another Haynes error or is something missing?
Thanks,
Juliet
Thanks,
Juliet
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
chinkostu
- x 30
Re: Xantia clutch
On mine theres a jubilee underneath the airbox and the one leading out of the top. Mine is a push fit after that, just yank it upwards!
Should be just enough room to adjust the cable from there. I lubed mine with LHM, adjusted it then lubed again. Worked loose a treat, and mine was stubbornly stiff!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Xantia97
Re: Xantia clutch
Great, thanks for the info, never thought of using LHM. Fingers-crossed I'll have a nice light clutch by end of play tomorrow.
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
chinkostu
- x 30
Re: Xantia clutch
It was all i had to hand haha! Used a syringe and worked the clutch pedal after each squirt. Still softer now 2 weeks on
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Xantia97
Re: Xantia clutch
Ah, so you syringed the LHM down inside the cable, good idea.
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
