DHallworth
- x 167
Re: I have become an Activa owner...Project Stictiva-V6
That's a right bugger, that's another one that I only bought 12 months ago! Wish I'd ordered a few now!
I can't believe how much stuff has gone NFP in the last 12 months!
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 2005
Donor car David,,,,it is the only way.
Also, prices, go silly at £500 odd for a RaM....you can get two on a donor for that and do a JimMod on them.
There seems to be a few items in LHD that are OK (for now) but RHD are NFP...like steering racks for the V6
DHallworth
- x 167
Well I can confirm that those bushes are NOT NFP Sticky.
I ordered 2 x 405911 from Robins & Day in Glasgow last week and they have arrived today. They do have a P in front of them which means they are a Peugeot part, not a Citroen part, I don't know if this makes a difference!
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
superloopy
- x 19
Are they identical then?
Mike
- x 2005
Do they have the narrow outer race/collar ?
superloopy
- x 19
What do you mean, that they aren't the same part with a Peugeot part number then??Stickyfinger wrote:Do they have the narrow outer race/collar ?
Mike
elma
- x 287
What does NFP actually stand for. I've got my own abbreviation but I'm sure its not right. Have you actually rung your Citroen dealer with the part number when you come across it? I got my hydractive strut tops from Citroen even though I found out they were NFP on the internet.
- x 5674
No Further Production?
- x 2005
no fracking part
- x 2005
Don't know, which is why I am asking, and I cannot see thru the plastic bag....My Citroen parts guys says they are NFP, as does CitService....so ?Northerner wrote:What do you mean, that they aren't the same part with a Peugeot part number then??Stickyfinger wrote:Do they have the narrow outer race/collar ?
DHallworth
- x 167
Here's pictures of the bush in the packaging. It's the same as the last one I bought...
Regards
David.
Regards
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 2005
Dats da Wabbit
DHallworth
- x 167
If we were to try and organise a group buy I'm happy to talk to my dealer about price.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 2005
Happy to put in for 3x on that unit.
But the answer to WHY there is a bush of such a complicated design on the lower mount is designed in, is still an open discussion.
As far as I can see the geometry of the roll bar does not change under/off load, the ball joint on top acting as a hinge/shock absorber.
As such, despite the opinions otherwise, and I value the time in use reports, I will replace the solid one Jim very kindly made for me with this resilient one as soon as I need to break the joint again (due to a tiny weep I will in the winter when stored). I can see only one reason, the reduction of shocking loads into the upper ball joint.
Similar
Similar
wurlycorner
- x 271
Have to say, the quality of that oem part looks terrible...
Nothing is square/true on it
Iain
CX DTR T2 Safari (silver)
Iain
