Had tyre changed now getting a catching noise
ej2095
Unread post by ej2095 »
Very odd if i sit idle the sounds gone.
When i drive its like something is catching on the wheel.
Had two tyres changed on the passenger side but i seem to remember one of the alloys had then balance weights on the inside on one of them.
Feeling the front wheel and the gap between that and the bit thats on teh car is very little..
Wondering if the weight is catching as the guy did take both wheels off at the same time.... (And prolly got the two mixed up)
Also its a 2.2 HDI and looks like needs a new silencer as mines rusting.. best place to get one and are they easy to fit?
C5 2.2 HDI Estate mk1 (With a anti theft fury dice device)
x 2938
Re: Had tyre changed now getting a catching noise
If he changed the tyres he would have (should have) re-balanced the wheels so makes no difference which he fitted where. It is possible that a poorly located weight might catch on something but it's also possible that one of the pad wear wires is touching so needs looking at
Can't help with the exhaust info.
chinkostu
x 30
Unread post by chinkostu »
Jack her up and rotate them by hand, see if you can hear it better.
Could be tyre noise, what tyres were fitted?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
ej2095
Will check this afternoon in work this morning... and will get back to you
x 1997
Unread post by Stickyfinger »
Do you have a label left on the tread ?.....I checked and did .........I did hear a slapping sound from the back :)
ej2095
Nope looks like they had hit the dust guard with the wheel trim n bent it on the calipar which was catching removed it and spun fine..
mind i did see him struggle to get wheel on for some reason
SaabC5
Unread post by SaabC5 »
I did mine on my 2.2 MkI a couple of years ago, rear box can be bought on eBay for £40 delivered from Germany. Get a new clamp while your at it, mine was so corroded it exploded as soon as i put a wrench on it. It's literally a clamp and a coupe of rubber hangers, dead easy if its off the ground on a 4 post lift, bit more difficult if its on the ground but please use axle stands for safety purposes. I
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour) :wink:
