MOT and brake force
chinkostu
x 30
Re: MOT and brake force
Unread post by chinkostu »
citronut wrote:
chinkostu wrote:
if you ever need to work on that car again, take a look at the bar that runs from the back of the booster to the pedal (across the top of the bulkhead)
theres a 13mm locknut that you can use to adjust the pedal travel. chances are they've nipped it out so theres a bit of free play in the brakes. Both my Saxo's had iffy feeling brakes until I adjusted them.
this is a Xantia we are talking her Mr chinkostu,
they do not have servo assisted brakes like the Saxo does, and the usual fault on the Saxo is the linkage at the bulkhead seizes up
I was referring to the saxo ;) ;)
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 94
Unread post by citronut »
citronut wrote:
Stickyfinger wrote: and what causes it ??
maybe an uninitiated MOT tester
Regards, malcolm.
x 94
chinkostu wrote:
citronut wrote: this is a Xantia we are talking her Mr chinkostu,
chinkostu wrote: I was referring to the saxo ;) ;)
sorry bud it certainly did not read that way to me anyway's :-D :wink:
Regards, malcolm.
chinkostu
x 30
I worded it poorly ;)
if you read it, i do say "both of my saxos" :rofl2:
regardless, i don't think theres any linkage adjustment on a xantia :lol:
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
c.morewood
x 55
Unread post by c.morewood »
I'm with you Malcolm .. just discovered he's about 23 and dosen't know a lot about hydraulic Citroens...
So I've read that the best way to test Xantia rear brakes is either a lot of weight in the back or suspension on high?
I'm wondering if thats correct so I can pass it on to him.. need to have a word about the travel and what force and efficiency he's expecting to see from the brakes.
I've heard he's quite a fair chap just uninitiated with the hydraulics.
Any thoughts from you guys about the force required/expected and efficiency expected from the brakes?
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
x 1481
Unread post by xantia_v6 »
The MOT brake machines compensate for axle weight. I had a xantia that failed on rear brake efficiency by a few percent. I took it home, put 200kg of concrete in the boot and took it back.... the brake efficiency was just the same. In that case I think the problem was the "performance" brake pads fitted by the previous owner did not have much grip when cold.
superloopy
x 19
Unread post by superloopy »
How is it then that the rear brakes silver up with a fully loaded car and dont seem to do anything when not loaded? How can the machine simulate the axle weight?
Mike
x 94
as far as i know the axle weight is calculated by VOSA's computer not through the rolling road/brake tester, as the car is logged on for the MOT through VOSA' s
data base,
because older cars that may not be on the data base the MOT tester has to either ask the person presenting the car, or try to look it up on a wall chart
Regards, malcolm.
superloopy
x 19
Thats my point. The fact that the rear axle requires 'extra' loading is lost to the majority of testers these days who will dial in the book values. Proof that the brakes need loading is surely that the disks themselves are very lightly used otherwise. Also explains why you cant properly bleed the rear brakes without the axle being loaded.
There is no pressure in the system otherwise so makes sense to me that without any loading the brakes are not effective resulting in marginal values. Chuck the extra weight in .. thats what i do if only to silver up my disks!
Mike
x 2006
Unread post by Stickyfinger »
In an EMPTY car, when on the road, the movement/ "throw" of the car loads the suspension constantly as does body roll etc, this will not be happening on a "static" body even if it is weight loaded as the system is self leveling.....I do not fully understand why weight when static on a roller would change that state ?
Is there an effect on the system if the front wheels are not rotating ?
How does suspension movement/loading effect pressures in the brake lines/system valves ?
superloopy
x 19
Try bleeding the back brakes without any load. It cant be done. Something to do with opening valves which i dont fully understand. Putting suspension on high as has been suggested has the same effect as loading the rear. No doubt someone will have an explanation for this.
Mike
x 2938
Here you are fellas, work it out for yourselves :) http://www.citroenet.org.uk/miscellaneo ... ics-1.html
superloopy
x 19
Gulp! It does mention brake force and load though across the axles. Anyone able to make sense?
Mike
x 1481
citronut wrote:as far as i know the axle weight is calculated by VOSA's computer not through the rolling road/brake tester, as the car is logged on for the MOT through VOSA' s
data base,
Quoting from the tester's manual
Code: Select all
For Class 4 vehicles the ATL system will automatically weigh the vehicle and this presented weight will be used for the brake efficiency calculations.
x 94
Northerner wrote:Thats my point. The fact that the rear axle requires 'extra' liading is lost to the majority of testers these days who will dial in the book values. Proof that the brakes need loading is surely that the disks themselves are very lightly used otherwise. Also explains why you cant properly bleed the rear brakes without the axle being loaded.
i have always understood you are ideally meant to present the car for an MOT unladen,
all my customers cars i take for MOT's i virtually never have a problen on the brake rollers unless there is an actual fault with the braking system,
like on a conventional suspended car with a compensator valve on the back axle, they do not test if the valve is operating on an MOT, but just make sure the lever arm is not seized/stuck
Regards, malcolm.
