x 1999
Re: I have become an Activa owner...Project Stictiva-V6
Unread post by Stickyfinger »
OK, I just took the seat out :)....and yes, reclining would of been easier :(
OK, I have both wheels off, cannot work out how to turn the 19mm cable adjuster nut on the caliper end as it just rotates the whole sleeve (on both sides), there is not a locking nut so does that mean I have to grip the metal collar on the end or the sleeve with mole grips ?
atm....handbrake needs to be on 5-7 clicks to hold the car....
x 8363
Stickyfinger wrote: atm....handbrake needs to be on 5-7 clicks to hold the car....
Hold on a moment, handbrakes aren't adjusted at the lever end, they're adjusted at the caliper end... No need to have the console out for just that.. Hope there was another reason [-o<
5-7 clicks is a tad marginal. Depends on the MOT tester. Having said that, don't go too far the other way. I'd look at 4 for hard-on...
Northern_Mike
I'm glad Adam is asleep now.
Sent from my SM-N9005 using Tapatalk
x 1999
LOL....matron !
consol.....So much for the book of lies .....!.sh1t !
So, the nuts on the cable/caliper ends then.....forward or back for tightening and best way to grip to prevent the guide tube rotating ?....being thick and being nagged to rush...grrrr
daviemck2006
x 496
Unread post by daviemck2006 »
4 what's for a hard on Jim[emoji48] [emoji13] [emoji23] [emoji23]
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 1485
Before you do anything, press the brake pedal to the floor (engine on of course....) 5 or 6 times. Might just need the internals adjusting up. If the cables are old, then chances are you will not be able to free the adjusters. You will need to clean the threads, then plus gas, then pair of spanners to break the lock, then hold the cable (gas pliers?) whilst you turn the nut.
chinkostu
x 30
Unread post by chinkostu »
can you get the end of the cable out of the caliper hook? if so, get some mole grips on the metal part AFTER the thread that the cable comes out of, and then go nuts with the plusgas and spanners. for mine I had to jam the molegrips against the strut and cracked the smaller locknut off, then try to free the larger nut off. if theres not a chance of doing that you'd have to try and hold the cable further up, but you run the risk of damaging the threads or the sheath that runs over it.
for adjusting it (on the side i could do at least!) what I did was wind them back up the thread so theres enough spare cable to get it back into the hook easily, then pull the cable end so the nuts are resting against the hub. tighten the larger one up and when you've got just a smidge of free-play in the cable, do the lock nut up :)
mine now comes on nice and tight after 2 clicks :shock:
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 1999
So, after a big fight and the deployment of a micro-flame on my nuts and mole grips to grip my shaft :)....got them free. Adjusted to Hard-On @3 clicks
Now the dash instruments.......................
daviemck2006
x 496
So you need hot nuts and a gripped shaft to attain hard on in 3! [emoji23]
Peugeot boxer 2016
In the family
x 1999
Took the seat out.....nuts with Lock-tight on.
double
x 8363
I've just exploded in laughter reading the last few posts but I cant tell my daughter, who's sitting here, why :twisted: :lol:
chinkostu
x 30
daviemck2006 wrote:So you need hot nuts and a gripped shaft to attain hard on in 3! [emoji23]
:rofl2: :rofl2: :rofl2: :rofl2:
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 1999
OK, Brakes done and adjusted, new motor in drivers seat, dash out and MPH dial face fitted, center console out and in for no reason, only a few screws left to fit (and wonder were that extra one came from ?).....rain tomorrow
chinkostu
x 30
Stickyfinger wrote:only a few screws left to fit (and wonder were that extra one came from ?).....rain tomorrow
I had a few of those when i stripped the interior out! They weren't from the seats so bugger knows where they came from :rofl2:
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 1999
save them, add them to mine then collect them from a few more people on the forum, over a year we could end up with a C1 vtr :)
