x 8422
Re: I have become an Activa owner...Project Stictiva-V6
Superloopy has another AxxTVA hasn't he?
x 1997
Unread post by Stickyfinger »
AAgggggggggggggggggggggggg......MOT booked for Friday morning at 10am........
and will you guys stop making me check the DVLA number plate site pls
Northern_Mike
Stickyfinger wrote:AAgggggggggggggggggggggggg......MOT booked for Friday morning at 10am
Good luck mate. Sure it'll be ok with all your hard work..
Sent from my SM-N9005 using Tapatalk
DHallworth
x 161
Unread post by DHallworth »
Best of luck Alasdair! Got everything crossed for you!
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 8422
DHallworth wrote:Best of luck Alasdair! Got everything crossed for you!
David.
Same here [-o<
chinkostu
x 30
Unread post by chinkostu »
Stickyfinger wrote:AAgggggggggggggggggggggggg......MOT booked for Friday morning at 10am........
Nothing I could see that would make it fail when I was down there AL! you've been quite meticulous in bringing her up to scratch. Heck, if it does fail it will be on something completely stupid like mine did :rofl2:
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 8422
Absolutely agree :-D Go for it Sticky, you'll be fine but I do understand... I have no nails at MOT time... I worry myself to a gibbering wreck made of jelly...
Always needlessly...
Northern_Mike
I'm more nervous at MOT time than I was when any of the kids were being born!
x 8422
Northern_Mike wrote:I'm more nervous at MOT time than I was when any of the kids were being born!
I know exactly what you mean Mike...
chinkostu
x 30
I always find if i'm confident in it passing they will find something i completely overlooked. The 206 went in and I was sure it would pass, having just spent the week doing the last few jobs. failed for a blowing exhaust (the clamp had finally given up and there was a button sized hole in the olive of the backbox) inner CV boot and then the kicker, corrosion within 30cm of a suspension mounting point. then the brakelight and headlight played funny buggers and blew ON THE WAY to the station :roll:
said corrosion? on the stupid bloody lip that sits under the bonnet scoop for the cabin air intake. it had rotten right through, but as it was attached to the strut tower itself, was a fail #-o
I took the Saxo in many, many years back and it failed on bloody bulbs of all things :rofl2:
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
Northern_Mike
Perversely I've taken cars down I was 100% sure that would fail yet they've passed..
x 1997
Final checks/adjustments...
HOW to take out the xantia center console ? to adjust the handbrake ?...................seats have armrest
chinkostu
x 30
From underneath Al unless you're changing the cables!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 1471
Unread post by xantia_v6 »
Centre console comes out in the usual way with the armrest folded back and the drivers seat set fully aft (and maybe reclined a bit).
Also (assuming there is too much movement in the handle) check the amount of movement in the arm on each caliper first, you can't adjust the cable to compensate for a seized adjuster in the caliper.
x 8422
Yep, as Mike says, motor the seats right back and recline the seat with the armrest back as far as possible.. Until it squashes into the back seat. You then will have loads of room...
