x 8391
Re: shortly to become an Activa owner...Project Stictiva
All four Sticky and lower it very carefully on two trolley jacks...
x 1996
Unread post by Stickyfinger »
CitroJim wrote:All four Sticky and lower it very carefully on two trolley jacks...
xantia_v6:
On thé non-activa version, the return connector can be reached by jacking up the car a little, removing the subframe bolts on one side and gently lowering the subframe.
If the plastic pipe is popping out of a rubber connector, put a small cable tie around the joint to increase the friction.
Err Gents, which one ?
Awwww.....Crap, that will be a PITA here with the limitations of the ground I am on.
I take it is a depressurise job and both wheels off ?
Disconnect the Dog Bone ?
How is the Book of Lies for this job ?, follow the "removal" section ?
x 1996
Well I got some lighting in, a couple of tools to move some wires and this is what I see....
Sitting behind the valve is this 4 way connector
With a Split in the top arm/socket of the connector itself No 13 below, more of a crack really as it looks hard, brittle and old by its brown colour.
Part No 13.....NFP !....so WTFH do I do now (? a link to a seller maybe)....any reason I cannot use a PAIR of Y connectors then feed these to a single Y connector ?
x 8391
They do seem to be failing quite often now Sticky and finding a replacement is getting a bit tricky as it's pretty much unique...
One must start to think of an alternative way of coupling the four pipes in question...
I've wondered about a lump of soft (but LHM resistant) plastic suitably drilled to take the pipes roughly in the style of the original... It's a case of finding some suitable material as not everything is adequately LHM resistant. Some stuff rapidly goes hard and other stuff rots very quickly.
x 1996
Well I think (?) I will get access with only one side of the sub-frame dropped...I will wait and see...
I have inspected the scrapper Activa and the same unit is both fitted and looks in good order.....so I have decided to be brutal in the morning and cut a hole in the boot :) BUT, I will measure and investigate for a neat modification to the boot floor in the V6 Activa to allow access to both sides via cut inspection holes..................this should be fun.
I see NO REASON why not to do this in the same way I see NO REASON to put a connector in a place impossible to get too (Class A stupid).
This will render the car static, not what I wanted but beggars and all that. I will move the car into the garage for more stripping next week.
So, the Green Goblin will be off to the crusher next week...............to be honest it will be good to get rid I NEED the space and next door will not have a scrap car parked there for long even if it is a good door stop/blocker :).
Will it be OK to leave the drain back tubes blocked up when the car is not running ?
x 8391
Yes, not a problem at all....
You're not the first to go in with a tin-opener to get at that junction!!
x 1996
Cheers Jim (again :) )
I will measure up with care with the aim of cutting out and making a bolt in inspection cover for my car from the scrap car floor. The angles of the pressing will even match and minimal work needed in side the V6 . A good flexible sealant around it and painted/undersealed, good to go with no visible modifications.
I find the placement of this item/joint one of the most ridiculous thinks I have seen for some time and in need of either changing of having access granted. As a bonus access to the other connections should also be improved.....you can bet with good odds that as soon as I fix this, a week later there will be another reason to go in there again :)
Skull
(Donor 2026)
x 381
Unread post by Skull »
I was thinking about the access plugs like the ones for the fuel pump in the tank but I guess you'll want a little more strength in that region - daft buggers putting it there :twisted:
Gary
x 1996
HELLO BOYS !......come out and PLAY !
Now tell me that is not the MOST RIDICULOUS placement of a Plastic Push-Fit oil pipe 4 way Union
Skull
(Donor 2026)
x 381
Watch the Customs and Excise faces light up when they see that concealment compartment you've made [-X They'll never believe you when you tell them what's in there :rofl2:
Gary
x 1996
Plan No.A
Blue is the plate from the scrapper floor, yellow is the hole in the V6Activa floor....too big ?
Plan No.B
x 8391
Gosh :-D That's made life so much easier.. If you need to get the ram pipes off it's a heck of a job normally but from there it's a doddle..
You need to make a template available to all us Activa owners now so we know exactly where to cut...
What did you use to make the cuts?
x 1996
look left :)
Template No.B looks better to me than the larger No.A.......Input on this Guys please
Northern_Mike
I like the larger one. It's not that much bigger and might save skinned knuckles.
Sent from my SM-N9005 using Tapatalk
x 8391
The right-hand 2/3rds of A for me as it gives useful access to the electrovalve too...
