Hi,
the power steering on my 306TD (130,000 miles) has gone quite stiff - it is more noticeable at speed than when stopped - steering feels 'dead'. the belt is ok (good condition, not glazed, no squeeling) , there has been no fluid loss. Front tire pressures are normal (35psi). This has not been a gradual degredation, it was quite pronounced coming on suddenly. I've not hit any curbs or potholes recently. It seems I'm looking at a replacement pump or steering rack. Does anyone have any tips on diagnosing which part to replace? or similar problems they would like to share?
306 Power Steering
I would drain all the power steering fluid, the rack problems generally creep up on you, if its started quite suddenly then it sounds like a blocked line or pump failure. As pumps are 100ish notes then I'd try clearing the fluid and lines first. If that doesnt solve it then pump from a breakers might.
I had a similar problem on the Berlingo recently. I changed the fluid and the problem went. It must have been a blockage in my case as the vehicle is only 2 years old and 35,000 miles.
Have a check of the U/J from the rack to column (I take it the 306 has one)I've seen them sieze on 205's and other non-PSA vehicles. The most recent was on a Fiesta, the steering went scary stiff and undrivable in a week, and was cured in 5 minutes with an oil can.
