Citroen C5 2.0 HDi Estate Banging noise from Drivers Rear
- x 94
Re: Citroen C5 2.0 HDi Estate Banging noise from Drivers Rea
aah now
i were thinking you had similar rear arms to the standard CS car, but no it is more like the 406
they can supply you most of the bushes separately, you just need the right ammo/part No.'s to aim at them
if you are able/would like to go this route to replace bush's only,
here is a screen shot of your cars rear suspenders
https://www.dropbox.com/s/qng0h3bcqo1m6 ... p.png?dl=0" onclick="window.open(this.href);return false;
there are several bushes that could cause a clonking noise, so i think unless someone on here has had similar with this rear end set up ,
i think it will be down to some poking/prodding and levering to find the culprit
pm. sent
pm. sent
Regards, malcolm.
OnlineStickyfinger
- x 2008
nice to see Aussie dealers are the same as over here then ......
- x 1240
Goodonya Geoff. I also am 76 and still doing my own repairs
but you have a better climate for it.
Estately
- x 23
Sounds like there may be metal to metal contact and a quick check (having noted the warnings of getting under a Citroen) that the rear arm is not hitting the under side of the sub frame. There should be a "bump stop" fitted into the sub frame and these can go AWOL.
They cost less than £10 per side from Citroen and can be fitted by locating and pushing into the locating hole in the sub frame which is above the suspension arm.
Hope that helps.
Andy.
Hope that helps.
Andy.
If it can happen it will.
tomfrog
mal old pal. how are you getting on with the part no? Any luck?Aussie Tomfrog.
tomfrog
Iwould like to explain the upper hub BUshs are rat sh"it. My back wheels are laying in .No noise but alot of side movement and body roll .Thanks Tomfrog
- x 94
i posted a screen shot above from service citroen relating directly to your cars chassis/VIN No./rear suspensiontomfrog wrote:mal old pal. how are you getting on with the part no? Any luck?Aussie Tomfrog.
just click on the dropbox link
regards malcolmcitronut wrote:aah now
pm. sent
Regards, malcolm.
qprdude
- x 14
Not any help at all, but I was hoping this thread would slip off the first forum page to give me a break. I can't look at the topic header without bursting out laughing. Surprised nobody has mentioned it so far.
Rick.
2013 Citroen DS 5 D/Sport
daviemck2006
- x 485
Does your rear end bang Rick [emoji90] [emoji12] [emoji48] [emoji23]qprdude wrote:Not any help at all, but I was holing this thread would slip off the first forum page to give me a break. I can't look at the topic header without bursting out laughing. Surprised nobody has mentioned it so far.![]()
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
old-un77
Rather like the BBC Typo, when they referred to a
LARGE HARDON COLLIDER
Bob
Bob
Northern_Mike
I think that was the Daily Mail wasn't it? However, that pales into insignificance alongside John Inverdale's recent faux-pas on live radio... I'll post it on the amusing joke thread though, not here..old-un77 wrote:Rather like the BBC Typo, when they referred to a
Bob
Sent from my SM-N9005 using Tapatalk
tomfrog
Citronut hello The diagram is correct . the bushs I want are the three in the wishbone . the upper hub bushs are the ones I mainly need .Sorry for all the confusion Thanks Tomfrog.
- x 94
typical the bush you require is the one they don't list separately, i see what you mean about rip off price
5175CN TRAILING ARM 165.82 GBP 198.98 GBP 198.98 GBP
5175CP TRAILING ARM 165.82 GBP 198.98 GBP 198.98 GBP
i think you need to remove and measure one of those bushes, then do a gooooogly search with the dimensions, there must be a bush out there of the same dimensions,
aim those part No.'s at your local motor factors
Regards, malcolm.
tomfrog
Thanks for your efforts Mal Very much appreciated Fair dinkum. IthinkI will have to go to cit dealer . sob so b sob.I have been playing around with these bushes for six months. part nos are same as in Ozland so same ripoff .Do you think the trailing arms would be hard to remove ?Labour is very expensive Approx $ 1200 aus. Any way, all the best in your endevours and .to all your CIT mates PS I. have POMMIE mate at shoeberryness? ESSEX Any where near you ? Cheers TOMFROG
- x 94
why should it cost $ 1200 for at the very most ( i would think ) a couple of hours labour = $600 per hour
:missile: :missile:
not near Shoeberryness im in East Sussex,
i will ask GSF if and how much they can do the arms for though,
maybe you should contact Addo ( Adam ) as he is in Oz ( the Wizard of Oz
i believe he has had much-us dealings with bushes
:missile: :missile: not near Shoeberryness im in East Sussex,
Regards, malcolm.
