Despite issues like this.... Don't worry about a thing
- x 8191
Re: shortly to become an Activa owner...Project Stictiva
It's all going to be fine Sticky!
- x 1980
Ummm.....even Steva-McQueed came over to inspect the growing Citroen collection
Frnt Brakes are horrid and vibrate (disks low low low)
Bad leak in rear ram....needed 1.5 lts LHM Plus before drive back....red light stayed off. (edit)
Leaking HP Pump, needs changing
No Radio code.
Spoiler damaged
Boot lid small crack
Rear roll Bar bush ??
Poor quality lacquer/some peal...PAINTED Black bumper inserts !
Rams are 1.5 years old
New Sunroof !
Engine is VERY smooth and pulls over 4k like a train
Active control seems 100%
No LHM leaks in Active system
NO Rust No RUST No RUST....anywhere
4 new Goodyear VRs
Gearbox quick and smooth
Use Zero Oil/Water on return
Start.Wed night
9pm...Drive to Portsmouth in my C5...
Sail as foot passenger at 10.45pm
Thurs
06.30 Dock Caen
9.30 Twingo to to Orleans
12.30 Arrive Orleans
2.30 Dump Twingo back to Europcar
3.30 Leave Orleans in a V6 Activa
10pm at Caen (ferry delayed till 11.30 loading 12.30 sail)
Friday
06.45 Arrive Portsmouth
09.15 Arrive Salisbury in Activa
11.30 Train from Salisbury to Portsmouth to pick up my car
2.30 Arrive home in C5
2.45 Lift to Salisbury to pick up Activa
3.30 Arrive home with the above
Fracking Kippered !
Anybody got a Dante Red car transport trailer with twin Axles on Activa Wheels ?.........................
the things you think about on a drive without a radio
No Radio code.
Spoiler damaged
New Sunroof !
4 new Goodyear VRs
Start.Wed night
Thurs
06.30 Dock Caen
Friday
Fracking Kippered !
- x 8191
Excellent
Ram bush is no problem.. See my website...
Can't stop, off to Friday karate training in two minutes...
Northern_Mike
My head would say that it would be better to register the LHD one over here and make it good and put up with LHD rather than go through all the hassle of putting the bits into a RHD shell.
That's just me and I learnt in an LHD and it doesn't bother me a jot.
Sent from my SM-N9005 using Tapatalk
- x 1980
I am beginning to think that as well, I will get it regd'ed up first as I have to strip parts/overhaul from the other two cars anyway and that will take time.
It will get repaired/serviced during the summer then off into the garage for the winter. Engine change, Re-Spray , Undercarriage clean/protection and maybe the Wheel side swop then.
.....I had a LHD Lancia Delta Integrale Phase2 for just over a year, I did not have many problems with that but did notice I used differing styles and overtaking places than the other car I had at the time. Like the Xantia it had (more) the power to make a decision to pass whenever you wish anyway without being a nutter and being silly. "Nutter speed" I keep for tracks
One benefit I did not consider was that because I have an Auto box in the C5 and the Kia (and that the Healey has not been out for 6 months), gear changing came very easy from early on
- x 1412
Congratulations on getting it back alive. Tell us more about the car, trim level etc.
- x 1980
Full black leather, electric (not heated), sunroof , wood, all the standard Exclusive stuff. New heater matrix (2 yr), Timing Belt and water pump (18 mths), both frnt bottom joints.....garaged last 5 years.
- x 1412
Very nice...
Your hydraulic leaks might both turn out to be easily fixed, the strut could be just a torn gaiter or dislodged return pipe. The pumps usually just need an O-ring or 2 replacing.
- x 1980
It is why I have two donor cars
The ram will need changing, I am pretty sure of that...The pump will be changed and rebuilt and shelved for later. The intent is to generate as many "boxed" spares as I can with them ready to fit when needed. (Jims Ram fix will do the job on the 2ltrs Ram so I will take that off first and fix this one later)
It is one of the reasons I am stripping the V6 Exclusive donor 1st so I can clear space. All the ancillary's should be off the next week ready for the engine to be pulled.
Anybody need a V6 Auto box ?
Northern_Mike
- x 1980
What we need is a massive big official FCF Barn !
- x 8191
I currently have two available, taking up space I need for my conversion...Stickyfinger wrote: Anybody need a V6 Auto box ?
We do indeed!Stickyfinger wrote:What we need is a massive big official FCF Barn !
- x 1980
- x 8191
Gosh, that'll be perfect!
A shame really.. I recall how scarce they were five years ago..... Now there's a glut of them...Stickyfinger wrote:V6 box will be dumped then
- x 1980
Yes, but space and the large number of removed spares I will need to keep dictate that I am brutal about this.as you say, a shame but thinking about it there are not many cars worth keeping that used the box.
Anyway its raining to day so I decided to keep at stripping the V6 so as to clear that garage asap for the V6 Activa. Spannering to relax after the last few days adventures to the land of wine and cheese !
Here are some quick shots of the V6 Activa
