x 1980
Re: shortly to become an Activa owner...Project Stictiva
Unread post by Stickyfinger »
Well I got the Rad out last night.....the bottom 5th was full of mud blocking the fins, the things you find :)
The Vice is great, with the Anvil end and the ability to rotate I am sure it will come in very handy....but where to bolt it to ?
Ahhhhhh.......... the smell of a new vice
x 8172
Now you need a good bench to bolt it to :wink:
Stickyfinger wrote: the smell of a new vice
Wouldn't know, never had one...
bxzx16v
x 34
Unread post by bxzx16v »
Looking forward to your updates Sticky, good luck with the work.
Mark
x 1980
More work today.
Popped down to FraudFords to get a new set of Alen Keys and bumped into a Mobile Air-Con guy in the car park....anyway for a Tenner he stopped by on his way home and emptied the gas....result.
Anyway that allowed me to get on with the Air Con Rad and pipes, started exhaust, various BSI etc removed and gloved in bags. And Yes, some corrosion on the connectors.
So V6 owners, how well does your car suck ??
And how well does it Blow ??
note the BIG restriction here, very poor.
Stripping goes on...all cleaned up as I go....so much crap from the low area of the rad, VERY much an area to look at when cleaning the car.
a leak discovered..
That's it for today.....and not one knuckle damaged
x 8172
That air intake hose is a real problem Sticky and you have to be so careful refitting the airbox to make sure it's all tickitty-boo
That split in the hydraulic return pipe is very common too... It can let go suddenly and dump all LHM and strand you..
As happened to my V6 last year in my nemesis town of Bicester :twisted:
An event that precipitated me getting a C1...
DHallworth
x 163
Unread post by DHallworth »
Great work, Sticky!
Looking forward to watching this progress.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
x 1980
CitroJim wrote:That air intake hose is a real problem Sticky and you have to be so careful refitting the airbox to make sure it's all tickitty-boo
I bet that split is the main cause of the LHM volume loss on this car then. I can see myself making a few modifications as I go on (whatever) I end up actually rebuilding.
Stripping, cleaning and prepping is hell when you have yet to get a car to put it all on :)
Looks like I will be off to France on Tuesday night/Wed............ohhh lala
x 8172
Stickyfinger wrote: Looks like I will be off to France on Tuesday night/Wed............ohhh lala
Do have a lovely time... I'm really looking forward to the Team WFA excursion to Paris next month....
x 1980
with the ring road and the Arc-de-Triomphe round-about. , I may still be there.
x 1980
Well that's it.....I have done the following
I have Booked the Ferry from Portsmouth to Caen as a foot passenger
I have Booked a Fiat500 for a trip "down south a little"
I have booked the Ferry with a Car for the return (call me a optimist)
I have booked the rental car for return to Caen (call me a Pessimist)
I have withdrawn Euros
I have agreed a "subject to" price with a nice French Citroen owner.....(call me hopeful)
? will I have an Activa next week (call me confused)
x 1392
Unread post by xantia_v6 »
Last time I booked a Fiat 500 I got a low-spec Corsa,..
x 8172
xantia_v6 wrote:Last time I booked a Fiat 500 I got a low-spec Corsa,..
That's awful!
x 1449
Vice: I've got one like that - the rotational element is useful, and not, in equal measures! You can't get it tight enough not to rotate if you apply some serious torque (threaded wheel bearing puller for example.... :lol: ), so it rotates to the stop at about 45deg, which then means the handle fouls the bench which is a bit of a PITA for getting stuff in and out, but you can live with it. I welded up a square of 2" angle and bolted the vice down through that through the bench top, then put a bit of 4x2 right under the edge of the bench to hold it up. Never checked the bench attachment to the wall, but I haven't manged to pull it off yet :mrgreen:
Fiat 500: I woudln't mourn the loss if you don't get one. I had one when I was doing the turbo on te C4 last year. I was underwhelmed to say the least. It just seemed wrong to me somehow. The stalk controls are masssive and out of all proportion, and the gear change is heavy and bulky. And the ride is bouncccccyyyyyy!!! Very overrated if you ask me, no idea what all the fuss is about!
x 8172
Ahh, so the Corsa might be the better option then...
Perhaps you'll be really lucky and get a C1/107/Aygo Sticky :wink:
x 1980
Looking forward to sticking my head out of the roof and sitting in the back seat for 3 hours......
Man this is a close run trip........problems today
They misread the "controll techique" and tell me just before lunch I cannot insure a car in France without a valid one.
French go to lunch for 1.5 hours, late back...PANIC
Call seller....WHY did you tell me all was OK and it is not ?? "yes, you hve no Ci !, but it is OK to drive...WTF ?? ", I give up and get him to call company direct.
Oh sorry, we made an error....all is OK now.....PS, we forgot to tell you, a 4% card charge has been added.....
take a breath now......
