Wipers have stopped working
- x 1434
Re: Wipers have stopped working
As Addo says, easy enough to change AFAIK (I have to do the one on our C4 Picasso which is the same / very similar). Early cars used a more expensive board - I'm yet to be convinced that the later (much cheaper
) board is compatible. If you post up the last 8 digits of the VIN I can check the correct part number and price. It could of course be a fault with the wiper motor, so changing the board would be a bit of a guess - it is however cheaper and easier than a wiper motor (there are 2, and they are £250 EACH!). Ideally, you would find someone with a similar car that you could swap the board over to check.... It could still be a battery fault, and if the batt is 3 or 4 years old, I might be inclined to start there.
vborovic
- Locked user account
- x 40
What I'd like to do with DiagBox (Lexia) on the car is to test the wiper motors ... there is a wiper test available, and you'll see how and whether they respond ... maybe there is an issue with the wiper stalk, or some other line of communication, so at least you'll know you have fully working wiper motors, and go troubleshoot some other areas ... as for the fusebox under the bonnet, I can't see how it could cause issues, unless it has been tampered with or damaged in any way(which should be visible)
- x 1434
It's more than just a fuse box - it's a network hub. Seems to be some failure of the internal networking parts which causes some signals to go astray. Ours is suffering loss of engine speed info to the ESP / ABS / handbrake ECU, and occasional loss of EGR info.
vborovic
- x 40
I'll see what the wiring diagrams say about it, and how it can affect the wipers ... it is indeed a hub for some other things, but I don't think (currently) the wipers could be blocked by it (just the wipers, and the other functions still work)
qprdude
- x 14
I was tempted to say, if the "diagnostic expert" was correct, and you need a new BSI unit, I'd show my a*se in the middle of Woking, but that might be tempting fate.
Rick.
2013 Citroen DS 5 D/Sport
- x 1971
I will bring my camera, wide angle lens or Macro ?
addo
- Sara Watson's Stalker
- x 95
qprdude
- x 14
Wide angle for the back, macro for the front.Stickyfinger wrote:I will bring my camera, wide angle lens or Macro ?
Rick.
Tucker9037
Still nothing guys. Tried new battery, tested all fuses and they are all getting power to them, checked wiring, still no further forward. I can buy a under bonnet fusebox replacement for £50 but I'm not so sure this can be the issue. Does anyone here from Northern Ireland have a lexia I could try and reprogramme the bsi on?
Tucker9037
Also I found this which may be of use to others.
http://service.citroen.com/dtt/IFD/AC/d ... iag169.pdf" onclick="window.open(this.href);return false;
Tucker9037
Ok quick update. I have had a friend take a look today and he reckons it could be the motor itself. Would the master motor ( driver side) stop the passenger side moving also if the master motor was the one at fault? I've went and got a brand new motor off eBay as I got it at a bargain price of £130.
vborovic
- x 40
I didn't have a go through the wiring diagrams, but logically it would make sense to turn off both motors to prevent mechanical damage (also, no sense of windshield wiping with just one wiper, right?) in case one gives out ... especially if the secondary one would be out (overlapping one under the other) ...
Tucker9037
Thanks for the replys. do believe the master wiper is on the driver side. It's the master and passenger side is the slave. I am hoping this will be it cured when I get it changed. I can't complain at the price either as its a brand new valeo motor for £130
