iPhone Connection for C5 2005
This section is for General Enquiries or for Systems not Covered Above
Johnny Bravo
Unread post by Johnny Bravo »
Hi Guys,
I have a question regarding connecting my iPhone 6 to my audio system in my Citroen C5 Exclusive 2005 model ( inc Sat Nav )
My previous car had a simple CD/Radio player installed with an auxiliary connection on the front to which I could connect a 3.5mm jack plug which in turn connected to a Belkin hands free kit which also charged the phone. This enabled me to take calls and play the music from my iPhone through the car's audio speaker system which suited me fine and worked well.
But my C5 does not have an auxiliary connection to do this so I wondered what was the best or simplest way to use my Iphone 6 with the inbuilt audio system.
I have tried to connect it using the red and white audio jack plug connectors in the glovebox but as soon as i start to drive this gets disabled as part of the vehicle safety features, so that is a non starter. I do not want to take the sim card out of the phone to take calls etc like the manual states I can because that is too much messing and it won't let me play my music that is on my phone either.
Could anyone tell me the best and simplest 'add-on' kit that I will need for my audio system please?
I don't mind having to remove parts of the dash if necessary as long as it works after.
Cheers!
Johnny Bravo :)
Jodyone
Re: iPhone Connection for C5 2005
Unread post by Jodyone »
Does it have a CD player in the boot? If so, could you hijack the CD input with an official Citroen USB box (eBay?), or a similar knockoff like this: http://www.amazon.co.uk/YATOUR-Digital- ... B005V756ZG" onclick="window.open(this.href);return false;
2006 C6 Exclusive, 2.7 HDi
vborovic
Locked user account
x 40
Unread post by vborovic »
Or even simpler, there are CD changer connector cables available that on the other side have a 3.5 stereo male/female connector (some variants have standard AUX male/female) ... depending on what kind of solution you're looking for ... but what Jody suggested is better ...
x 1974
Unread post by Stickyfinger »
Shoot me if I remember incorrectly, but one of the inputs is for the audio Aux channel and should not shut off. It is the video that should shut off when moving.
I use this now but used a simple direct jack line in the Mk1 and Mk1Face......that said, the volume via the "box" is crap.
http://www.amazon.co.uk/VicTsing-Blueto ... merReviews" onclick="window.open(this.href);return false;
The only real way is to add bits like me or exchange the head unit.......none of the Higher Spec fitted systems worked well without a second Sim Card anyway.
Johnny Bravo
Thanks for your replies - Jodyone - vborovic - Stickyfinger.
Im quite frustrated in the fact that a car of this status does not have an auxiliary connection for mobile phones etc...
The amount of electronic stuff installed with the car is great but it lacks one auxiliary connection which seems rather stupid.
If this helps at all this is what I was using with my previous car and in order to carry on using the same bit of kit all I need is an auxiliary connection that connects to the car's inbuilt audio system so that I can play music from my iPhone though the car's speakers and also use it as a handsfree kit for phone calls to ensure safe driving.
Here is the Belkin Handsfree Kit I used before:-
http://www.amazon.co.uk/Belkin-TuneBase ... +handsfree" onclick="window.open(this.href);return false;
It also includes an FM radio and will control the fast forward and next track functions on the iPhone and best of all I can use my sat nav on my iPhone with announcements coming through the car speakers auto-quietening the music etc.
I will investigate the audio connections in the glove compartment again to make sure that they will not solve my problem as 'Stickyfinger' stated, if that does work I will be very happy.
I will also investigate the connections on the Clarion CD Changer which is situated under the drivers seat to see if there is an auxiliary connection that I could use there because I don't really use CD's for music in the car.
Thanks again!
Johnny Bravo
x 1974
The Best way if you do not wish to use the CD player is a conversion type plug for that feed, even Bluetooth
http://www.connects2.co.uk/c2/C2RangePr ... tgroupid=0
Diana radovanova
New User
Unread post by Diana radovanova »
Hello,
Could you help me How to connect my samsung s6 to Citroen c5-2005 year?
On one site is written mp3 and on the other site is written gsm.
Is this a slot for cim card?
x 6958
You can't connect any external phone as there is no Bluetooth on this model. If you have the RT3 Navidrive system you will have the option of inserting a SIM card to use the internal telephone.
Some later versions of the RT3 had an MP3 compatible CD player but no Bluetooth and no BT streaming.
Quackers
x 17
Unread post by Quackers »
I have a 2007 C5 with the satnav so the same system i believe, and i can confirm if you press source until AUX input is selected it does not cut off when driving as stickyfinger says, it only cuts off if you go into the main menu and select the video mode.
x 6958
He said the Aux AUDIO does not shut off, only the video which is correct.
