bxzx16v
- x 34
Re: Citrojim's Xantia V6, C1 and Activa Tales
Will you be at the CCC Northern show Jim this year?
Mark
Mark
- x 8431
If they let me have a visa for entry into Yorkshire and it doesn't clash with any Karate grading then yes, I certainly will be Markbxzx16v wrote:Will you be at the CCC Northern show Jim this year?
- x 94
Jim you need to speak to Mr M Harker he could probably fix thatCitroJim wrote:If they let me have a visabxzx16v wrote:Will you be at the CCC Northern show Jim this year?
Regards, malcolm.
- x 8431
I really quite fancy a campervan based on a Visa Malcolm
I wonder if Mr. Harker has one of those?
- x 94
so you fancy roaming in a Romahome then JimCitroJim wrote:I really quite fancy a campervan based on a Visa Malcolm![]()
http://www.gumtree.com/campervans-motor ... n+romahome" onclick="window.open(this.href);return false;
Regards, malcolm.
- x 8431
- x 8431
It's been a gorgeous day down here today and I had thoughts about giving the V6 and the C1 a much-needed wash but after realising how cold it still was in the shade and that my hose pipe was frozen I wimped out..
Instead I gave the V6 a good check over and a warm-up run around my test route and then came back and gave the C1 an oil and filter change...
A very easy job indeed.
Despite the mayo in the very top of the engine and the dipstick tube the oil itself was clean and free of cream...
That's it's first oil change. The C1 has now done nearly 2500 miles...
Now back to working on a resilient database solution for the forum...
bxzx16v
- x 34
My old 2.0hdi dispatch used to suffer condensation build up Jim in the oil fill cap, the berlingo isn't too bad though for some reason.
Mark
Mark
daviemck2006
- x 485
Shaun's 107 has done 9000 miles in 4 months! It's due it's first MOT shortly and has an extended peugeot warranty starting on its 3rd birthday. It's in need of two tyres and a service. He is putting it to the Peugeot dealer he bought it from. They have a deal on just now, an intermediate service and mot for £119. The service is oil all filters all fluids topped up, everything bar spark plugs. It will get plugs before it goes in there. The oil is still clean and there is no mayo on filler cap or dipstick, but then it does 2x42 miles 5 days a week plus every second Saturday so gets well heated up.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 8431
I 'll assume he drives with a bit of enthusiasm too Daviedaviemck2006 wrote:The oil is still clean and there is no mayo on filler cap or dipstick, but then it does 2x42 miles 5 days a week plus every second Saturday so gets well heated up.
I was amazed after taking mine for a good run yesterday to get the oil really hot how that was not achieved
I can see why the oil never gets hot on short, cold runs...
It needs a sump-warmer
- x 94
hang a tray under the sump with a couple of tea lights in itCitroJim wrote:is in the direct blast of cold air...
Regards, malcolm.
- x 8431
citronut wrote:hang a tray under the sump with a couple of tea lights in itCitroJim wrote:is in the direct blast of cold air...
It needs a sump-warmer![]()
, dont drive tooooo fast though or they might go out
- x 3298
You could always get another one of those dash heaters, and fit it to the sump.
- x 8431
Good idea JamesHell Razor5543 wrote:You could always get another one of those dash heaters, and fit it to the sump.
- x 8431
Gutted
The pool is closed this morning due to someone suffering diarrhoea in it last evening
Such an event forces a 24 hour closedown
