Windscreen Washers not Working.
Gazman
Unread post by Gazman »
Be looking on different forums on how to rectify this problem.
Had a go at trying to fix the problem today.
Remove the front bumper to access the washer tank very straight forward hought.
On inspection of the washer bottle and the pump everything looked ok. No leaks or cracks and the pump seal was ok too.
So would there be anything else I could look for to solve the problem.
Regards
Gazman.
Citroen C5 2.2 SX Estate
elma
x 287
Re: Windscreen Washers not Working.
Unread post by elma »
Fuse would have been my first port of call.
Bandit12
x 12
Unread post by Bandit12 »
Can you hear the pump working when you operate the washers? If not then yes I would start at the fuse too.
Bandit
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone) :(
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade) 8-)
Gazman
Checked the fuse that's 'ok.
Gazman
Can't hear the pump working.
elma
x 287
Does it work if you attach it to another live wire? If not the pump is dead. If it does maybe the switch or relay (if fitted) or a wiring fault. Sounds like the pump may be the culprit to me.
Gazman
Put the amp tester on the fuse and operated the stork on column and got a reading. Checked the connection to the pump but no reading. Can these connection fail not much to them.
Stempy
Unread post by Stempy »
Pump is a common failure, they are cheap enough so replace it anyway while it's in bits.
Lexia ponce
Bandit12
x 12
Yup does sound like the pump is the problem. I suggest after replacing the pump you refill the water bottle and check for leaks before putting the front bumper back on. I didnt and assumed it would be fine-Doh :oops: Water water everywhere and not a drop to drink :lol:
Bandit
Gazman
Got me a new pump today from Euro Parts for £9.94 bargain.
Replaced the pump with the new one and tried to operate the washers but nothing was working. Away to cut a long story short turns out the connection was faulty too. New connection fitted and washers are now working fine.
Just out of interest I tried the old pump with the new connection pump still not working.
Thanks everyone for your help and advice on this matter.
