- x 695
Re: Citrojim's Xantia V6, C1 and Activa Tales
Water pump impeller come adrift or broken Jim ?
- x 8408
That's what we're going to look at next Simon. Praying it is that...Mandrake wrote:Water pump impeller come adrift or broken Jim ?
If it's the HG then the job is going to be big as we'll also overhaul its 4HP20 at the same time...
- x 1463
If you need a late model (small diameter) ES9 water pump, I have one here that I bought in error.CitroJim wrote:That's what we're going to look at next Simon. Praying it is that...Mandrake wrote:Water pump impeller come adrift or broken Jim ?
- x 8408
This particular 407 is a 2.0 16V Hdi diesel Mike but thanks for the offer
I doubt the water pumps are the same
- x 1463
Well you could change the engine...CitroJim wrote:This particular 407 is a 2.0 16V Hdi diesel Mike but thanks for the offer![]()
- x 1490
Funnily enough it's not the same, Jim....
I recalled something odd about the 2.0 16V Diesel cam belt - looked it up, and remembered what it is - there is no injection pump - it's driven off the other end of one of the cams. Looks like you need a tool to lock the crank shaft via the starter aperture / bottom of the flywheel to undo the crank pulley bolt....
addo
- Sara Watson's Stalker
- x 95
- x 8408
Thanks Gentlemen
I shall take appropriate care..
I already note the second cam is driven by a little chain in the head...
addo
- x 95
- x 8408
Re:
Ahh. I was wondering if that was the gotcha was when swimming this morning...addo wrote:Yes; therein lies the risk as the tensioner only works in normal direction of rotation.
Strange what you think about when doing the strokes...
I shall take care...
- x 1490
Lighty had similar trouble with a 1.6 HDi 16V - he wound it back a bit to get the stretchy aux belt on, and unwound the cam chain in the process
The belt change is covered in the C5 BOL, Jim - shout if you want me to send you a scan of it. Belt run (just there and back) is more akin to a single cam petrol engine - it might even be possible without removing the engine mount!
- x 8408
If you could drop me a scan of the relevant pages I'd be eternally grateful, many thinks indeed Richard
I've had a look and I reckon removing the engine mount will give a great deal more access and it's easy enough to do... Once the mount is out of the way and the aux. belt is off the cambelt looks very visible...
Looking forward to it, a new engine to get my teeth into...
- x 1490
- x 8408
- x 1490
Someone's been there before me
Cambelt section: https://picasaweb.google.com/1173210214 ... 9615882898
Nothing special mentioned about the water pump - unbolt and remove
