please help! Strut Tops.
x 8401
Re: please help! Strut Tops.
I have used Elastomer for XM Strut Tops and can thoroughly recommend them :-D
They did a very good job.
darbuck
x 289
Unread post by darbuck »
I dont know about the strut tops but I've just put a set of original birth droplinks on the c5 they seem like better quality than fistline or as good as febi
Sent from my ALCATEL ONE TOUCH 903 using Tapatalk 2
Darren
ACTIVE8
x 6
Unread post by ACTIVE8 »
Ford Prefect wrote:Look up elastomer.eu - a company in Lithuania.
They renew your old struts for 160€ + 21% VAT (one pair).
The package from Lithuania to Sweden costs 22€ + VAT and it took nearly three weeks so be patient...
Elastomer also renew XM struts and BX (although I never heard that BX have problems with the struts...?)
As the BX came before the Xantia one would expect it (the Xantia) to be, moving forward in design, and engineering issues/problems, and not create an issue that as you say was not present on the earlier model.
ACTIVA
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
To be honest the Xantia ALSO went backwards with the Height Corrector Cradles, and the stupidly complex double levers, which sieze up all the time, unlike any other hydro Citoren before them that used a completely different and simpler setup.
A very sad...
1994 XM 2.1 d auto
ACTIVE8
x 6
citroenxm wrote:To be honest the Xantia ALSO went backwards with the Height Corrector Cradles, and the stupidly complex double levers, which sieze up all the time, unlike any other hydro Citroën before them that used a completely different and simpler setup.
So how does that happen designed correctly, and better previously, and then NOT!
Different management, change of staff, now not designed by engineers more like the accountants, parts prices etc it all brings about a fait accompli !
ACTIVA
citroenxm
Fallen Hero
x 70
Sorry, im not sure I decode your comment to be agreeing with me or disagreeing... 8-[ :?
A very sad...
1994 XM 2.1 d auto
harryp
(Donor 2022)
x 73
Unread post by harryp »
Following this excellent post with interest - I guess we all are, as it's only a matter of time IMHO!! :(
I guess Activ8 means they have followed Frauds Value Engineering concepts and have (un?)knowingly designed in a fault by making it ever cheaper to manufacture; after all they are sadly only interested in the warranty life. It's left to us to pick up the pieces and the Forum to educate us "how to", for which I am always sincerely grateful - thanks guys, all of you =D> =D> =D>
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
x 1996
Unread post by Stickyfinger »
As p[er the latest film from the Citroen Museum, Xantia's + XM's and the whole of the 90's are to be forgotten anyway :)
superloopy
x 19
Unread post by superloopy »
Mine are almost forgotten about .... last runs out being a distant memory ..
TD excepted. Stil doing a sterling job. Both Activas and V6 aren't earning their keep.
Sent from my LG-D855 using Tapatalk
Mike
harryp
(Donor 2022)
x 73
" aren't earning their keep"
smiles per mile down then?
Regards, Harry
superloopy
x 19
Re: RE: Re: please help! Strut Tops.
harryp wrote:" aren't earning their keep"
Non existent.
Mike
c.morewood
x 55
Unread post by c.morewood »
I'd always assumed that Xantia Mk2's were immune to the strut top failure and therefore hadn't checked them too carefully. I had a little chat with Jim earlier this year, about the rubber coating on the underside being forced off by rust, but left it at that till now.
I did a good bit of work this year for the MOT replacing wishbone bushes/bolts CV joint rubbers, droplinks, inner and outer trackrods, brake cables, pads, discs all round and the top engine mount bushes.. (bottom to be done this week).
I happened to read the all of this thread whilst on my last night shift and though I'd check the strut tops inside. Lo and behold I found the rubber coating cracking and on peeling this away, found rusty metal underneath. I removed some more and foung the whole bell of the strut top was rusty underneath the rubber.. So I thought I'd check the recently acquired 36k Mk2 and it too has the cracked rubber with rust underneath.
Whilst I'm not saying that it is near failure in either case, I'm not taking the chance and have made my initial contact with Elastomer for refurbishment in the summer.
It just might be worth checking out your Mk2's for the cracking rubber.
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
chinkostu
x 30
Unread post by chinkostu »
If anyones sending some to elastomer i might get mine off the car in my time off and send them off too, save postage!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
c.morewood
x 55
I'm aiming for the beginning of July
'94 Fiat TipoTd 40K
falling-out-with-my-car
x 25
I repaired the cracking rubbers with rubber cement I got some from a chap who sells used tyres and patches them to sell on as part worns. But not before applying a good two coats if k- rust to the plates the rubbers are supposed to be protecting. I then siliconed the rubbers back into position excluding as much air as humanly possible. U then applied wax oil thinned with 10% white spirit around the bottom if the bells in the inner wings. A job well worth doing. She is 19 this year and still no corrosion.
Sent from my GoFone_GF50X using Tapatalk
