Calling C5 X7 (Series 2) Owners HELP please
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi X7 owners
Can any of you please tell me, is there Eolys Fluid fitted to 2.0 16v HDi 138 models 2008 year??? IS there a tank to top up???
We have one in the family now, but the anti pollution warning popped up and put the management light on BUT did not limit power or revs...
Id like to check it anyway, and top it up if it does. Its been a city car so I think a few runs on our open road might clear it up!
Thanks.
A very sad...
1994 XM 2.1 d auto
x 1983
Re: Calling C5 X7 (Series 2) Owners HELP please
Unread post by Stickyfinger »
Fist job is yes, 70 in 4th for 15 mins should help :), did the warning say anything ?
My new one had a DePop fault showing before I got it, it was the pump pressure regulator. SO NOT always a FAP problem.
You will need to get it on a Lexia to check the cause of the problem (not just a basic code reader, the Citroen type)
http://www.frenchcarforum.co.uk/forum/v ... m.php?f=15" onclick="window.open(this.href);return false;
citroenxm
Fallen Hero
x 70
Ok Sticky, we have a lexia so that will be a to do and see what exactley we have. did not have chance to put it on today..
All it did was put the engine management light on and said Anti Pollution Fault... and that was all. But engine light stayed on..
I shall come back here once I know what LExia tells me...
Cheers
A very sad...
1994 XM 2.1 d auto
x 3567
Details of what additive are listed here:
http://www.frenchcarforum.co.uk/forum/v ... =3&t=48558" onclick="window.open(this.href);return false;
cheers
citroenxm
Fallen Hero
x 70
Ahh so its basically in the same place as the S1 Facelift model then... Cheers
A very sad...
1994 XM 2.1 d auto
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Take a look at this post Paul.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
citroenxm
Fallen Hero
x 70
Stickyfinger wrote:Fist job is yes, 70 in 4th for 15 mins should help :), did the warning say anything ?
Went to mums today and was pleased to learn the management light is out and theree no depollution fault and car is driving all well again with full power... I shall get under anyway and check out the Eolys level...
thanks richard thats spot on it is still in the same place as mk.1 c5s ..
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
Re: Calling C5 X7 (Series 2) Owners HELP more issues
Hi...
Ok, depollution issue never came on again, and I never got round to seeing where the tank is....
Anyway, I have a far bigger problem.. Randomly, the car will simply cut out on driving, doesnt matter if its over run, slight accelleration, hard, cruiseing what ever...
It is infact a danerious issue, because the car wont start again, untill you, well they, actually pull over and stop and try again.
Lexia tells my theres apparently a power loss momenterally to the "Engine Relay Unit".. .. the car does start again after pulling over and starting. But the cutting out is random, AND at any speed. They want to go away but are worried it happens on the outside lane of the motorway or something.
Have wiring diagrams been issued for these X7s yet? Anyone got any.. OR does anyone know where the Relay unit is???
Thanks!
A very sad...
1994 XM 2.1 d auto
x 3567
I believe there was a recall for a faulty oil level sensor reading which would cause some cars to cut out randomly. Might be worth checking on the recalls website to see if your one was affected ?
http://www.dft.gov.uk/vosa/apps/recalls/default.asp" onclick="window.open(this.href);return false;
vborovic
Locked user account
x 40
Unread post by vborovic »
I'll give it a go, but first, I need to identify the part you're looking for (translate into proper croatian) ... :D
citroenxm
Fallen Hero
x 70
You know its interesting you mention that! because it did/does flash up low oil pressure too!!!!
Wow, amazing! Will look into it.
A very sad...
1994 XM 2.1 d auto
vborovic
Locked user account
x 40
Here's also some mention about the recalls: http://www.theaa.com/allaboutcars/recal ... &makeId=A7" onclick="window.open(this.href);return false;
http://www.citroenownersclub.co.uk/c5-n ... blems.html" onclick="window.open(this.href);return false;
citroenxm
Fallen Hero
x 70
Ok, so it mentions an ECU software update... Is this something I can do with my LExia stuff or best dealer???
A very sad...
1994 XM 2.1 d auto
vborovic
Locked user account
x 40
I think only the dealers have access to the ECU updates via the official PSA repair network (unless you know of a mechanic in the network that would do that for you without the Service) ...
x 3567
Might be worth checking with the dealers to see if it's ever been updated (if it needs it that is !), as if it does need updating, but hasn't been done yet, I'd be pushing for the dealer to do it at their (Citroen's) cost as it's a safety / recall related item.
