just back from taking the pooch up the woods and raking out some bike trails for the weekend, pulled up the drive put windows up, as the drivers got to the top there was a nasty Crady ping noise and some bits falling off inside the door.
am i roight in thinking this is most probably the plastic widow clip?? window stayed up btw.
mo 7 here??
Crackedy Ping noise as window closed - Xantia
- x 168
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
- x 106
Re: Crackedy Ping noise as window closed - Xantia
Ay up!
Could be but could also be a sign that some of the plastic mouldings in the regulator assembly have cracked. Although winders are not expensive, they are a double dyed villain to replace - not much room inside those doors.....
RIP
BX16TRS (x2) (Fifi 4 and 5)
BX19DTR (Fifi 2)
BX14E (x2) (Fifi 1 and 3)
RIP
BX19DTR (Fifi 2)
- x 168
Hmmmmmn, so a bit of gaffer tape and some investigation required then! Job for tomorrow!
'58 C2 Code
'58 C2 Code
- x 232
Something I just went through, could be the same failure? http://www.frenchcarforum.co.uk/forum/v ... =3&t=49915" onclick="window.open(this.href);return false;
Whatever you do, don't assume the window will stay up!
- x 168
am now reading through your thread mike as after popping the door card off and investigating it appears i too have the same issue tyou had!
'58 C2 Code
'58 C2 Code
- x 71
The cable on S2 is useual, I think mainly the use of a thinner cable then S1 winders...
Ive never re wired them, however, ive never attempted to either. Not my sort of patiece .. lol..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
I'll bet a pound to a penny it's the plastic slide block that has broken.
A new one on ebay is about £8. I've changed one. It's not difficult. I bought a kit of slide block, cables and spool. The only thing that was correct fitment was the slide block.
I think a member called Faz had the same problem recently.
I've some photos of the regulator assembly if you want them. There is a tensioner assembly at the bottom of the regulator that falls apart when the cable tension is released from it.
There is a rubber bush and metal clip that pushes through the glass and the plastic slide block locks into it. If this bush is damaged then the slide block will be working at an angle and won't last long. (ask me how I know!) I've some new rubber bushes here if you want one. they are sold in bags of 5 and I only needed 1. (P M me)
The cables on mine had some minor kinks in them where they wrapped themselves around the spool, just like yours. I re-used them with no problem
HTH
HTH
MJM
1999 Dante red Xantia Exclusive 2,0 petrol. No smelly diesel for me. Now re-homed
2007 Wicked Red C5 Exclusive. Now a smelly diesel automatic for me.
