Stop solenoid
lazza
Stop solenoid
Unread post by lazza »
HI
I noticed fuel leaking from the stop solenoid of my Bosch VE - type fuel pump. I presume in this case I can simply screw it off and change the seal with no need to take the pump apart??
Larry
(1996 Citroen Xantia 1.9TD LX with aircon)
Living in exile in Spain
Running on 100% veggie in summer
x 8417
Re: Stop solenoid
Yes, you can Larry, Access is a tadette challenging but possible if your pump is unarmoured. You need a 24mm spanner and you may have to modify it a bit to fit and be fit for purpose...
Under the solenoid you'll find an O ring...
Be cautious when lifting the solenoid body, it's likely the plunger will be left behind and inside the plunger is a small coil spring. Be careful neither get lost.
Use a bit of Vaseline to 'glue' it all together when reassembling...
Be sure any new O ring you might use is certified to be diesel proof. Not all are. Try to get one made of Viton....
x 94
Re: Stop solenoid
Unread post by citronut »
i would think if you can see the solenoid it will not have the immobiliser amour over it,
also its not usually the O ring at the base that leaks but the internal seal, in this case you will need to replace the complete solenoid
Regards, malcolm.
lazza
Re: Stop solenoid
Ah ok, thanks i'll hopefully take it off tomorrow
