You should get your handbrake fixed then.Xantippa wrote:With automatic transmission it´s pretty much impossible to sit in traffic lights without brake lights.
c5 x7 2009 rear light, plug burning out??
Northern_Mike
Re: c5 x7 2009 rear light, plug burning out??
old-un77
if I am stuck behind a persistent brake pedal pusher, I position my car so that I can see his mirrors,I turn on my headlights till he releases the pedal, and so on.
btw way why DO people insist on using indicators in a dedicated turn lane, like out of supermarket car parks, and never bother to use indicators on roundabouts????
vborovic
- Locked user account
- x 40
I guess the break thing is somewhat cultural ...
... on our roads, it's a minority that doesn't break on the traffic light, so I guess you'd burn out your headlights over here ...
... I do understand the reasoning, and can agree on it that the driver behind is bothered by the more intensive red glow, but honestly, what bothers me more on the roads are drivers who don't want to switch from high to dipped beam in the middle of the night while driving towards you ...
- x 94
i was always taught at a stop junction or red trafic lights you are meant ( in a manual at least ) to take it out of gear and have the hand brake on,
this is what always constituted as a stop,
as modern car brake lights are so so much brighter these days, it is not comfortable sitting behind a car at lights with there brake lights burning into your eye ball,
Regards, malcolm.
- x 94
not if the idle speed is set correctlyXantippa wrote:With automatic transmission it´s pretty much impossible to sit in traffic lights without brake lights.
Regards, malcolm.
Xantippa
- x 29
So you mean I should put gear on N and activate electric handbrake always at traffic lights?!!northern_mike wrote:You should get your handbrake fixed then.Xantippa wrote:With automatic transmission it´s pretty much impossible to sit in traffic lights without brake lights.
Btw, If I remember correctly, that doesn´t help, because the handbrake activates brakelights too.
Xantippa
- x 29
I don´t understand what you mean? My idle speed is set correctly (how can it not be on these modern HDi-engines?).citronut wrote:not if the idle speed is set correctlyXantippa wrote:With automatic transmission it´s pretty much impossible to sit in traffic lights without brake lights.
And I thought that it´s normal for a car with automatic transmission to move forward when on D and no brakes on?
- x 1996
Yes, If it does not hold the car it is not working correctlyXantippa wrote:So you mean I should put gear on N and activate electric handbrake always at traffic lights?!!northern_mike wrote:You should get your handbrake fixed then.Xantippa wrote:With automatic transmission it´s pretty much impossible to sit in traffic lights without brake lights.
Btw, If I remember correctly, that doesn´t help, because the handbrake activates brake lights too.
Yes, you take a geared car out so why not an Automatic ?, it is basic road manners to the driver behind you. Why would you wish or not care about causing them discomfort and reduce their night vision ?
and
mine does not
- x 3296
When I was learning to drive my instructor taught me to use the handbrake and put the car in neutral if I felt that I was going to be stopped for more than 5 seconds. That was mainly for good manners (not dazzling the drivers behind), as well as making the car more secure (if I were hit up the back it is likely my foot would slip off the brake pedal).
- x 1996
or smash your ankle joint when they impactHell Razor5543 wrote:(if I were hit up the back it is likely my foot would slip off the brake pedal).
- x 94
thereStickyfinger wrote: or smash
that would stop them holding there lazer brake light on in front of youStickyfinger wrote: ankle joint
Regards, malcolm.
Xantippa
- x 29
Well, If you knew how much it does cost to replace hand brake cables on C5 X7 with electric hand brake, you wouldn´t use it too much.
Richard_C
- (Donor 2026)
- x 230
It is possible to have that combination without sitting at traffic lights with your foot on the brake.rear lights, indicator, rear fogs all on at once it won't cope and ..
In some places we have hills, fog and junctions that you need to slow down for
Richard_C
- x 1996
and if appropriate, your lights should be used, I do not think anybody thinks otherwise.Richard_C wrote:It is possible to have that combination without sitting at traffic lights with your foot on the brake.rear lights, indicator, rear fogs all on at once it won't cope and ..
As for cables, Lube e'm and Use e.m or Loose e'm.
gavramis
Hello
I have the same problem with my c5 x7 2.0hdi 140ps 2010 model. The left rear led indicator stops working every week. When i stop the car after 1 hour works fine. Checked With my lexia and found errors like front right indicator problem,rear left indicator problem..etc for all indicator...
The connectors are all ok and no melting points.
I will attempt to make a by pass ground to the rear left light and i will let you know if the problem is still here.
Thanks for the technical ideas....
Keep the good job.
George
Keep the good job.
George
