Peugeot 107 Twin Headlight Parts
Zelandeth
x 1607
Unread post by Zelandeth »
When I bought my 107 back in 2009 (really doesn't feel like five years ago!) I specified a few of the dealer fit cosmetic options. Was my first new car, so I had a bit of fun with being able to make it mine.
One of the options was a set of twin circular headlights. Turned out to be a good functional upgrade too as they work really well (especially when aimed right rather than skywards as the dealer left them...).
Sadly though both of the outer lenses got cracked last year within about a week of each other when I got pelted with stones going through some roadworks.
Finding replacement units has proven somewhat hard, the size (5 1/2" if I remember right) doesn't appear to be at all common. The dealer I bought the car from closed shortly after I got the car, and the only other one in the area was less than useless - and flat out refused to admit that the light kit existed, despite me having the part number and Pug SP brochure in hand!
I did try Googling both the Pug and Hella part numbers with no luck.
So it's had the standard lights back in for the last year or so - but I would really like to get the proper ones in again given they weren't cheap.
Anyone got a clue where I might get the replacement bits from and what they will likely cost?
Will try to get a couple of photos up tomorrow to show what I'm talking about.
Cheers in advance folks.
Current fleet:
x 94
Re: Peugeot 107 Twin Headlight Parts
Unread post by citronut »
i would have thought any pug dealer should be able to either get them for you, or at least give you the OE part No.'s so you can do a goooogly search with the No.'s
Regards, malcolm.
x 94
here are all the part No.'s for RHD 107 head lamps that come up on pug service box
6208 74
HEADLIGHT ASSEMBLY
LEFT
LEFT HAND DRIVE UNTIL RPO 12872 EXCEPT ANIMATION RANGE 2012
6206 74
RIGHT
6208 75
LEFT
RIGHT HAND DRIVE UNTIL RPO 12872 EXCEPT ANIMATION RANGE 2012
6206 75
RIGHT
16 079 784 80
LEFT
ANIMATION RANGE 2012 AND RIGHT HAND DRIVE SINCE RPO 12873
16 079 780 80
RIGHT
Regards, malcolm.
