Leaky Xantia
x 8406
Re: Leaky Xantia
Excellent, that's great news :-D
chinkostu
x 30
Re: Leaky Xantia
Unread post by chinkostu »
Dead on the money for the hose size too. I did notice the hose gets thicker about a foot after the join, when it meets the subframe, im guessing it has a sleeve due to its proximity to the elements?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 8406
Re: Leaky Xantia
chinkostu wrote:I did notice the hose gets thicker about a foot after the join, when it meets the subframe, im guessing it has a sleeve due to its proximity to the elements?
It does indeed :-D I've known the inner leak into the outer before now and that can make a leak very hard to pin down as the leak origin can be a long way from where it appears...
chinkostu
x 30
Re: Leaky Xantia
Is there anything you don't know? ;)
Last thing, theres a rubber Y shaped adaptor near the passenger wheel, while tinkering today it was looking a little worn. Are these easily available from citroen?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 94
Re: Leaky Xantia
Unread post by citronut »
chinkostu wrote:thats an idea. would need a good few inches of metal hose though, is it usual to be able to order by length? i assume it would need flanges/ ferrules (what on earth are they called? the nobbly bits!) too to stop it simply sliding off?
i do not usually add/create any nobbly bits as the rubber againgst the metal with hose clamps fitted are usually enough on the pipe,
Regards, malcolm.
x 8406
Re: Leaky Xantia
chinkostu wrote:Is there anything you don't know? ;)
A lot, believe me...
chinkostu wrote:Last thing, theres a rubber Y shaped adaptor near the passenger wheel, while tinkering today it was looking a little worn. Are these easily available from citroen?
Can you pop a picture of it up please?
I think I know what it is but to be sure a picture would be valuable. Sounds like it's the strut return and a common enough failure point. Easy to replace and still very much available.
chinkostu
x 30
Re: Leaky Xantia
Can do, will wait until sunlight though! One pipe does lead from the HC into this Y piece, that much i can see
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 8406
Re: Leaky Xantia
chinkostu wrote:Can do, will wait until sunlight though! One pipe does lead from the HC into this Y piece, that much i can see
Ahh! Is it a little Y-Piece with quite small diameter hoses attached? If so then that's just the leakage return from the HC connecting into the main leakage return circuit back to the LHM reservoir..
You may find one intended for windscreen washer hose or even a fish tank will do the job... Check whatever you use for LHM resistance though...
chinkostu
x 30
Re: Leaky Xantia
Awesome! Annoying that its only weeping now ive been in the area near it!!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
