Just woundering if anyone could help I have a c8 2.0 hdi
I brought it as a non runner (snapped belt) and ended up changing the engine but It starts and runs fine no management lights on but no powet on take off almost as If
It has not got a turbo
Checked pipes no splits no engine warning lights read with lexia no fault codes there is a slight missing around 3000 rpm but not all the time any ideas would be appreciated
Malc
citroen c8 no power
rabenson
Re: citroen c8 no power
MAF sensor - I had same problem on my C5 HDI no fault codes but no power, new MAF sorted it fine!
2007 C6 2,7 HDI exclusive 95k
2004 C5 VTR HDI 103k
m300td
Thanks will give it a try but it looks new but it is a copy part
lexia owner nr telford
- x 5672
They have a reputation of having a rather short life.m300td wrote:Thanks will give it a try but it looks new but it is a copy part
Check the air filter - moisture can get sucked in and soak the filter and MAF, corroding it.
m300td
changed the maf and it has made no difference whatsoever has problems revving past 3000 rpm
really holding back wants to go but just holding back new air filter oil filter fuel filter
