new abs sensor high at 1135 ohms and abs ECU checks
x 8368
Re: new abs sensor high at 1135 ohms and abs ECU checks
Hell Razor5543 wrote:That is what I meant.
James, you are a good lad :-D
Dave1987
Unread post by Dave1987 »
I do not have a Lexia system but own a newly developed SVDI PSA commander, can that diagnose abs sensor?
x 8368
If it will talk to an S2 Xantia it should be able to Dave but be aware the Xantia is not EOBD II even though the socket looks like it is...
Sent from my Lumia 900 using Tapatalk
x 3306
N/S/F calliper replaced, so handbrake now reliable (it lets go when it should). Now got to replace the O/S/R ABS sensor (after Plus Gassing the 3 bolts on the heat shield). That one shows infinite resistance.
John Plum
x 5
Unread post by John Plum »
Like me, a duff front sensor. I've always found the sensor bolts are liable to round off and mole grips tricky just there. In case you get interested, The sockets I mentioned above were great for the job - cost me £19 for 8mm to about 16 or 18mm and was delivered next day, last Sunday.
John
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
x 3306
I have got a set of Aston Super Wrenches. Although the head is a bit large, if it can get a grip it hangs on like a bull mastiff!
John Plum
x 5
I gratefully received Richard's brake pipe, :wink: and stripped off mine in preparation. Both 3.5mm pipe seals stayed put in their respective sockets (calliper and k-splitter).
:?: What's the trick in removing these, ready for replacements? I don't really want to try using the old ones…. not best practice.
John Plum
x 8368
A pair of pointed tweezers John. Grab hold of the seal with the tweezers and screw it out...
John Plum
x 5
Cheers Jim, I'll get a pair of those - something I wanted for my first aid kit anyway. :-)
John Plum
x 3306
A reasonable alternative (provided you do not intend to re-use the seals) is a thin woodscrew. It does knacker the seal, but it gets them out.
John Plum
x 5
That's what occurred to me James, but wasn't sure. Anyway, found some tweezers at the chemist earlier - cheap cosmetic variety, not the surgical ones I would have liked... better for pulling out splinters.
I didn't know people reused seals. I'm still waiting for some, could I reuse these without pulling them out... Or should I wait?
John Plum
x 8368
Always best to pull them out John and then you know they're seated correctly on the new pipe.
If you're careful with the tweezers they'll be easily reusable...
John Plum
x 5
Reusable?! Wow, well why not... That's good.
John Plum
x 8368
Yep, if they don't show any damage. You'll see screw threads moulded into them but that's OK. Also, you often find a very fine strand of rubber on them. remove that gently too before reuse...
John Plum
x 5
That's exactly what I found.
Cheers.
John Plum
