Auxiliary Heater testing Fuel Burning Heater
KP
x 27
Unread post by KP »
Right,
The fbh fitted to the HDI, can it be forced to run from a lexia for testing to make sure it works and if not at least I'll get a fault thrown up hopefully!!
x 3296
Re: Auxiliary Heater testing Fuel Burning Heater
I believe (but I am NOT certain) that the Lexia can see auxiliary heaters if fitted. I have seen something about them in a global scan.
KP
x 27
Unread post by KP »
I have never ever played with one in lexia before but have seen the section so am wondering if they allow some testing or such like of the whole unit and if so what test?
x 3296
Pass. Gracie doesn't have any, so I have no way of knowing how they are tested. I just remember seeing something about them, possibly in a 'comfort' section?
KP
x 27
Unread post by KP »
Doh :(
x 3296
I DO know you can test the cooling fans on an HDI, as I have done so. Bit weird though, as on slow speed both turn, but on high speed only one turns. Not a fault, as with the A/C on both fans turn at high speed. Based on this, it is possible you can test the heater, but the engine might need to be running, as the heater needs the coolant to be circulating for it to work.
http://www.frenchcarforum.co.uk/forum/v ... =3&t=49752" onclick="window.open(this.href);return false;
x 8409
I've not seen any Lexia successfully access the heater but it can be tested by linking out its
Sent from my Lumia 900 using Tapatalk
x 8409
Control relay in the engine bay fusebox. The relay is controlled normally by the engine ecu and it'll kick the heater into life if the air is below 9 degrees and the coolant below 60 degrees.
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
As Jim says you can't fire up the heater with Lexia, just bridging the relay but you must have the engine running. The usual problems that stop the heater running are a duff glow plug, non running venting fan or clogged gauze. If the heater hasn't run for a while it's worth removing it so that you can upend it to empty it of diesel as they can fill up in which case it'll never run. For further info these heaters are used in VW Transporter minibuses so a quick search should reveal all, failing that if you get stuck I might be able to find some for you.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
KP
x 27
Unread post by KP »
So they fill with fuel and won't run! That's stupid!
Does it have no built in pump? I'm just wanting to fire it up to see if it runs. The ones in the rangeys seem light years ahead in comparison :(
Well best to go and have a play tomorrow when I have a chance.
Any idea which pins need shorting to test fire it up does anyone know?
I know from past reading any fbh needs to be run red hot every now and again otherwise they clog with soot and crud :(
Fired up the rangey one this morning and by golly is it worth its weight :D
DickieG
x 33
KP wrote:Does it have no built in pump? I'm just wanting to fire it up to see if it runs. The ones in the rangeys seem light years ahead in comparison
Yes it has an in line pump just prior to the heater, the heater in your Range Rover is more than likely the very same unit,,,, :wink:
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
KP
x 27
Unread post by KP »
Ahhh so the engine doesn't need to run! It can be set to fire and circulate heat within the engine cooling system, albeit upto about 80-90'c before the stat kicks in and let's it go to the front radiator....
This does sound promising!!
x 8409
You do need the engine running to test as if the water is not circulating through the heater it'll very soon cut-out due to the over-temperature sensor operating.
x 1995
Unread post by Stickyfinger »
if you have Google translate this is some info from Mother Russia :)
http://autoklimat.by/product/binar.2917/" onclick="window.open(this.href);return false;
KP
x 27
Unread post by KP »
But if it has a pump Jim is that not circulating or is the pump on a different circuit?
