Hi, i have this permanent error in the injection ecu when reading with lexia
car is c5 '06 diesel with 150k
yesterday, on hard acceleration it came up with errors about the DPF and went into limp home mode, about max 10km/h , luckily had laptop with lexia and clearing faults in injection ecu got me going
my lexia doesnt seem to interface with the injection ecu as well as i believe it should, as some of the parameter reading dont seem correct and i cant seem to do a forced regen.
does any one know what this error is about ?
"maximum additive level in the particle filter" error
haydent
- x 3
SaabC5
Re: "maximum additive level in the particle filter" error
Maximum additive level in the particle filter? Do you mean maximum carbon level in the DPF? If its at its maximum level no forced regen will work anyway, the DPF will need to come off the car and be cleaned through using a caustic wheel cleaner type solution and a jet wash lance.
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
haydent
- x 3
thankyou for your reply this is the exact error:
- x 1493
Pretty sure that that means that the additive residue (ie ash) limit has been reached in the DPF. Either needs to be cleaned or replaced....
SaabC5
What Richard said, your DPF is blocked. If you wind the window down you'll probably hear a hissing sound where the exhaust gasses are escaping through the exhaust joints because the DPF can't flow properly.
haydent
- x 3
ok , ill look into that. thanks. So i looked at the pressure differential in lexia and it shows 0. as i said i think my lexia does not talk properly with the injection ecu, as it says it does not recognise it when connecting to it. ive read of others having trouble talking to the injection ecu too. mine is a siemens 803a
do you guys know anything about that issue ?
SaabC5
Bosch system on mine.
haydent
- x 3
So i hooked car up to snap on diagnostics tool today which actually communicates with the injection ecu better than the lexia...
and i was able to see fluctuating exhaust diferential pressure readings with rpm, and also that it had regened recently, there was still eolys in the tank and the filter load was at 4% so i started to think maybe the filter is not blocked...
so just on a chance i googled the error code number (P1445), and found a pug forum with a member with the same thing, (likely same engine/ecu), http://www.peugeotforums.com/forums/407 ... 445-15077/" onclick="window.open(this.href);return false;
they understood it to mean too much additive has been used through the dpf, and its time for a replacement filter, EOL (end of life). and suggested just doing the replacement option in Peugeot planent (pug equivalent of lexia) , but not actually replace the filter as i assume its likely still ok and working. they report no problems, and the error gone away.
so anyway thats what im trying next, and it make more sense with the wording of the error, especially considering there are other errors for a blocked filter.
the snap on tool reported the error as: P1445 "Diesel additive system quantity too high"
here are some photos:
- x 1493
It's blocked, or the DP sensor is knacked. Was that DP curve taken stationary? DP should not exceed 50-60mbar in that case.....
haydent
- x 3
i was stationary, you can see when i rev it, at idle it is 0mbar, the 2 graphs correlate at same time, so as you see top one go up (revs) the bottom one goes up too, (pressure)
do you think that pressure still seems excessive given the rpm ?
KP
- x 27
I would run it through a stationary regen cycle to ensure its fully flushed and see if another member can post up what theirs is like when running so you can compare pressure differentials.
I'd also think about taking it out and standing it on one end and with the end pointing to the sky squirt oven cleaner in it until it foams out the top, leave for 30mins and repeat until the oven cleaner spray can is empty. Then leave another hour and wash out over a drain as there will be A LOT of soot that comes out of the thing.
This should then be followed by the pug advice and then try again for a short run with the car
MikeT
- x 232
Old thread revival. I have this "permamanent fault" too and investigation shows the DPF is getting regenerated just fine (soot load goes back down to 3% on standard regens and went down to 0% on a forced regeneration) with no other additive-related faults so it does appear either the filter has outlasted it's predicted life (75,000miles) or mine was previously replaced without telling the ECU.
Apparently, the ECU keeps a tally of total additive used in the DPF as the cerin does not get combusted in the regeneration process and eventually blocks the filter over the speciified mileage.
I'll see if I can find the option to tell the ECU the DPF has been replaced and see if that cures it.
MikeT
- x 232
Hmm, not easy but got there in the end.MikeT wrote:I'll see if I can find the option to tell the ECU the DPF has been replaced and see if that cures it.
First likely option Particle Filter menu to test the DPF for soot loading to see if it needs replacing - nope, only for cars made after 2009.
Second option to replace the DPF itself - this function is not possible.
In a different submenu I found a counter reset option which changed the count from 84g to zero.
Success!
Only 4 more permanent faults left to demistify and rectify....
jgra1
- (Donor 2021)
- x 36
hi all! long time no speak.
My x7 has logged a p1445 recently, just noticed it tonight with Diag.
When looking at the exhaust-train menu, my DPF is showing 100%, my eel fluid (or what its called) remaining is about 1L
so, I am guessing really I should tear the DPF off, and clean it.. then reset something or other (2 things?) and see what happens.
Also, the car has developed an annoying misfire at 1500-1800 RPM, most noticeable in 3rd, but there in other gears.. the car shudders... is there a tiny chance this could be related to the DPF?
Has anyone removed a 163 RHH DPF before? I havent looked under the car for, well, ever.. not sure what I will find and how tricky it may be to remove the thing..
thanks,
John
ps. the average KM per last 10 regens is about 250, but the error logged - I think - says the last regen was 1800km ago!
thanks,
John
- x 6946
Hi John
Well take your pick, but the code would indicate that the limit of additive has been injected into the filter from the codes:
How many miles has it got on it now John?
- Additive adding : The quantity of additive injected into the particulate emission filter has exceeded the maximum threshold
- Additive system : Maximum additive in the particle filter threshold
- Purge Flow Sensor Circuit High Input
