Xantia 2.1 td rough starting..update
myheadhurts
jeremy
One way of checking for air in the fuel is to replace the last bit fo the fuel pipe nearest the pump with clear plastic and see whats going on.
I expect you have a bosch pump - leakoff pipes make a difference too and allow air in. On a roto-diesel they just leak.
http://www.andyspares.com/discussionfor ... IC_ID=9187
jeremy
jeremy
JohnD
- x 72
NiSk
JohnD
- x 72
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by NiSk</i>
Surely a '98 Xantia TD12 would have the Lucas EPIC pump??
//NiSk
Yes!
//NiSk
Yes!
myheadhurts
As JohnD says the fuel pipes are clear plastic on my car , thought i'd have a look this morning before going to gsf as it's the first chance i've had all week to look in the daylight.Before starting the car both pipes (to and from fuel filter) looked ok.. no air bubbles.Then I started the car , the pipe from the primer bulb to the filter remained clear but after running for a couple of secs the pipe from the filter to the(lucas) pump has quite a bit of air in it this is accompanied by the coughing and spluttering i'm trying to cure.This then clears after running for a few mins with only the occasional air bubble visible the engine then runs fine.It seems to me that air is somehow getting into the filter housing,has anybody got any suggestions as to what i need to replace first ?
beezer
I have posted elsewhere a possibility with the symptoms you mention. I have a Peugeot 205 that had a problem that garages could not trace. It got worse - conked out after shorter journeys. I eventually traced it to the hoses at the tank (205 was accessible under back seat) which had gone porous. Worth a look. Bubbles from the filter to the pump sounds very much like it - you could check the copper washers at the filter unions too.
NiSk
JohnD
- x 72
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">It seems to me that air is somehow getting into the filter housing,has anybody got any suggestions as to what i need to replace first ?
It might be that the lid isn't air tight. Remove the four screws and check in the joint that it's clean. Also check that if there's a rubber gasket it isn't damaged. Tighten down the screws in a diagonal sequence. Have a look at that 2 inch piece of rubber tube with its crimped clips.
oilyspanner
Get a couple of feet of leak off pipe, replace the lot, also remove and examine if not replace the blanking off ones, cured a similar problem on my ZX , fuel ran back, after a couple of hours it would stumble and splutter for a bit, overnight it would not go at all come the end without priming, one of the genuine rubber stop end pipes on the injector had a small split, replaced it using a piece of braided leak off pipe with a small bolt screwed into it, total cure, if that fails replace the fuel filter.
Stewart
Stewart
