Hello Everyone
x 5675
Re: Hello Everyone
You have removed or turned out of the way the 'hockey stick' bolts?
doctle
x 223
Re: Hello Everyone
Unread post by doctle »
myglaren wrote:You have removed or turned out of the way the 'hockey stick' bolts?
Hi Mate,
I did remove the 2 hockey stick bolts yesterday The bearing just wont move, I have the shaft pulled towards the drivers side now and the gearbox is back in. Only 74 k on the car but it seems to have been neglected.
Oh buggle
x 8427
Re: Hello Everyone
They can be utter ***** to move.
I've resorted to a specially ground cold chisel to act as a punch and walloped the bearing with a 4 lb club hammer before now and on one occasion actually shattered the bearing in the housing...
Generally though if you attack them with a cold chisel (ground so as to fit snugly against the drive shaft lip) rotate the shaft as you land blows they do normally give up gracefully.
doctle
x 223
Re: Hello Everyone
I'm doing it on the ground so space is limited. Any way of removing it that doesn't involve a grinder?
Oh buggle
doctle
x 223
Re: Hello Everyone
CitroJim wrote:They can be utter ***** to move.
Thanks mate I'll give it another go after church tomorrow if I wreck the bearing is it new shaft time? There's more skin on a rice pudding than on my hands since Friday I still have the belt to do :(
Oh buggle
doctle
x 223
Thanks guys
Car is back together thanks everyone for the help advice and info :)
Oh buggle
x 8427
Re: Thanks guys
doctle wrote:Car is back together thanks everyone for the help advice and info :)
Great news :-D
How did the driveshaft centre bearing go in the end?
doctle
x 223
Re: Thanks guys
Great news :-D
Hi, It wouldn't move. I unbolted the carrier from the engine and aligned it when fitting the gearbox. took a while but it's back driving. There was plenty of wear left on the clutch but the pressure plate was very rusted and the release bearing was in shreds.
Oh buggle
x 8427
Re: Thanks guys
doctle wrote:
Great news :-D
Great stuff.. At least the job is all nicely done now. I trust you replaced the complete clutch and not only the release bearing....
jgra1
(Donor 2021)
x 36
Re: Hello Everyone
Unread post by jgra1 »
good stuff Doctle
I had a V6 406 coupe with a stuck intermediate bearing, very frustrating.. in the end I took the whole auto box and what was left of driveshaft to an autobox specialist..
He put all of it on an old oil barrel, and hit with a serious lump hammer.. many times,,
it came apart then ;)
John
doctle
x 223
Re: Thanks guys
Hi Jim,
Yes all replaced it's too much work to split it again in a year.
Thanks again you guys are all very helpful
I'll be back with more questions soon
Paul
Oh buggle
x 8427
Re: Hello Everyone
jgra1 wrote: I had a V6 406 coupe with a stuck intermediate bearing, very frustrating.. in the end I took the whole auto box and what was left of driveshaft to an autobox specialist..
I remember that well John and in fact I have a spare 4HP20 here with exactly the same problem. It has the stub of a drive shaft stuck in it. A stub because most of the drive shaft got cut off after many attempts to remove it failed!!!
I'll most likely deal with it when I strip the 'box to overhaul it...
Paul, excellent :-D Keep the questions coming :wink:
