Cost for replacing EGR valve?
osx
(Donor 2022)
x 15
Unread post by osx »
Anyone got an idea how much would it cost to replace a faulty EGR valve? Don't think it is something I can do as it seems to be difficult to access.
C5 X7 Exclusive 2.0 HDi Auto
waynedance
x 8
Re: Cost for replacing EGR valve?
Unread post by waynedance »
What car do you have?
Doh just looked at your profile, does not show up on Tapatalk.
Volvo S80 D5.........
C5 2.2HDi Exclusive 2003 manual (now gone).
2009 Renault Megane, the misses drive.
Had a 1988 BX 19TRS Auto many moons ago.
Forgive any spelling mistakes, it's the phone not me.
x 1496
Assuming it's the early 140PS unit, Citroen quote £260 for the valve :rofl2: OE ones on the bay for £120, which is more like it. Appears to be on the back of the engine, so I'm guessing it's a git to change. Ball park 3-4 hours to change? So at an Indy you are probably looking at £350 - £400.... :evil:
waynedance
x 8
Just changed a seat leons at work and that was a 4.5 hour job and a bill of over £630.
So yeah some are a real pig do to do.
osx
(Donor 2022)
x 15
Citroen quote about £500+VAT and £200+VAT at the Indy. No idea why the difference.
SaabC5
Unread post by SaabC5 »
Is the valve faulty or just gummed up with carbon deposits? Have you tried a spray can of EGR cleaner down the pipe to the valve? I've had good results using a can of Wynns EGR cleaner. Spray it and let it soak for half hour before starting up and then giving it a few short bursts while the engine runs. (long bursts will stall the engine)
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour) :wink:
x 2938
osx wrote:Citroen quote about £500+VAT and £200+VAT at the Indy. No idea why the difference.
The indi doesn't have to have the staff factory trained, keep a hundred grands worth of spares and a hundred grands worth of special tools in stock or be obliged to employ sales staff to turn over a quota of vehicles to keep the franchise :-D
osx
(Donor 2022)
x 15
SaabC5 wrote:Is the valve faulty or just gummed up with carbon deposits? Have you tried a spray can of EGR cleaner down the pipe to the valve? I've had good results using a can of Wynns EGR cleaner. Spray it and let it soak for half hour before starting up and then giving it a few short bursts while the engine runs. (long bursts will stall the engine)
Tried it but didn't make a difference. Think it is stuck open.
x 3565
If I read my DocBackup correctly, the job of replacing the EGR valve in-situ is timed at just under 2 hours and is rated easy. The only specialist tools needed are pliers to remove a clip !
osx
(Donor 2022)
x 15
How long would blanking the EGR take then? I can barely see it so think better access would be from underneath.
x 3565
osx wrote:How long would blanking the EGR take then?
I'd guess around the same time as you've got to get to the same bits.
There is an actuator test for the EGR valve that can be performed with a Lexia. A ticking (like a clock) apparently shows the EGR valve is working fine.... either that, or your problem is you've got a clock stuck in the mechanism :wink:
SwissSPEC
Unread post by SwissSPEC »
Just out of interest, does blanking off the EGR, increase engine performance & make the car more economical?
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
Northern_Mike
No. Well, it made no difference to my 2.0 HDi C5 that I had a couple of years ago. Slightly worse economy, not as pleasant to drive. Berlingo much the same until it got fed up and put the engine warning light on.
Sent from my SM-N9005 using Tapatalk
osx
(Donor 2022)
x 15
EGR replaced and car back to normal. Last week or two it was difficult to keep economy over 40mpg so I am sure it will improve. Slightly more expensive at the end (£310) as I opted for a more expensive valve. Should I have asked them to replace the cam belt as well to save some time or is it a completely different job?
x 3565
osx wrote:Should I have asked them to replace the cam belt as well to save some time or is it a completely different job?
Completely different jobs. The only common denominators would be disconnection of the battery and handing you the bill at the end !
