alternator belt
basil
alternator belt
Unread post by basil »
How much tension should there be on a alternator/ac belt[?]
At tickover the tensioner is wobbling in and out but at increased revs it stops wobbling,the bottom run of the belt flaps up and down at low revs and is still at more revs [:I].Is this correct[?]
Xan 19td a/c
________
Uggs
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Sounds too loose. Under firm thumb pressure there should be around 5mm of movement on the longest stretch between pulleys.
TheWorker
Unread post by TheWorker »
if its R reg onwards have a look at the manual tensioner to see if the square hole is, if its at the bottomish shine a torch at the auto adjuster spring to see if the bush has worn out
Stuart McB
Unread post by Stuart McB »
I agree with JohnD. As a rule of thumb a quarter of an inch deflection under mild hand pressure on the longest run of the belt is about right.
basil
Thanks for the advice it is a 95n xan.
Also the adjustable pulley is not as free running as the other two smaller pulleys.Would some wd40 be ok to free it up[?]
________
Ferrari f2001 history
alan s
RIP 2010
x 6
Unread post by alan s »
Be wary using WD40 on anything with a bearing involved.
It works good to penetrate into a rusty thread but it's also a pretty efficient degreaser and has the habit of washing grease out of bearings which then subsequently seize.
Alan S
espzetec
Unread post by espzetec »
my belt wobbles too. however its not loose. it doesnt squeel at idle but i get a bit of a minute squeek when i do about 70mph? in fact i think the belt is too tight as i could not get it on when i replace it. i had to take the alternator off and then put the belt on. the alternator was then levered back into position before re-fixing it.
JohnD
(Donor 2022)
x 72
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by espzetec</i>
Did you release the manual tensioner? Is it the correct belt?
reblack68
Unread post by reblack68 »
I had the same problem on my Renault diesel. It transpired that I had followed the wrong route and the water pump was now running backwards.
alan s
RIP 2010
x 6
Speaking of manual jockey wheel/tensioners, I have heard that this part is no longer available (for BXs) but it does have an SKF part number on it so may be used on something else.
If all else fails, I reckon a BX16V cambelt tensioner would almost fit although the diameter would be smaller and so a smaller circumference belt would be required.
Re-routing the belt (and using a shorter one) <b>without</b> using the tensioner doesn't work as it reduces the area around the circumference the belt contacts and then regardless of tension applied will slip and eventually destroy the harmonic balancer.
Just thought I'd drop that one in based on bitter experience.[V]
Alan S
basil
What is the harmonic balancer?
________
Triumph speed triple
alan s
RIP 2010
x 6
The pulley mounted on the crankshaft that has a rubber centre vulcanised between the boss of the pulley and the V pulley section. It is there to reduce vibration and often, particularly in the cases of BXs, seperates due to age, oil contamination or ovetightening or slipping of belts which causes it to overheat due to friction. Often when people have problems getting belts to adjust correctly, it's due to this part of the pulley flexing.
Alan S
Stinkwheel
Unread post by Stinkwheel »
Isnt that similar to a flux capacator? But you only get them on CX turbos i think :-)
basil
Update-have rechecked the belt tension,I adjusted it with the engine running.As it was tightend a rattling noise started so I decreased the tension until it stopped.At this tension the sprung wheel still wobbles.
Any ideas?
________
FOURTH-GENERATION CHEVROLET CAMARO HISTORY
Mads
Unread post by Mads »
Changed the tensioner on my Xantia due to a wobbling wheel. New wheel also wobbles [V], guess thats the price of experience [:I]. Good thing it's a lot cheaper than paying a pro to expand on his [8D]
