x 8417
Re: Citrojim's Xantia, C1 and XM Tales
KP wrote:Fingers crossed Jim :)
It passed Will and with no advisories :-D
That's all of them now done for a year and apart from my V6 needing a new backbox and the girl's cars needing servicing I'm all up to date on the car front...
Northern_Mike
Good news Jim.. I'm also all up to date for a year with cars. I even bought the right wheel bolts for the Berlingo spare today from the dealer!
Sent from my SM-N9005 using Tapatalk
KP
x 27
Unread post by KP »
Wish I was as up to date Jim!
Maybe xm still needs a brake cable and o ring on the lhm pump and the rangey is just off for some work and then I need to get it trough it's mot never mind the golf I'm picking up tomorrow and the C2 GT I picked up the other night
x 5672
Yep, quite snappy, not that is was slow before.
Hardly broken at all Jim. Nice one :)
Sent from my castle in the sky using smoke signals.
x 8417
KP wrote: Maybe xm still needs a brake cable and o ring on the lhm pump and the rangey is just off for some work and then I need to get it trough it's mot never mind the golf I'm picking up tomorrow and the C2 GT I picked up the other night
My goodness Will, you're becoming quite the wheeler-dealer!
myglaren wrote: Hardly broken at all Jim. Nice one :)
Thanks Steve :-D Only a few Avatars got hurt during the migration so not bad at all!
I'm sure Superloopy will be happy to see Tapatalk is still good too!
PavlosV6
Unread post by PavlosV6 »
CitroJim wrote: Only a few Avatars got hurt during the migration so not bad at all!
Let's see if mine did :?:
Paul
'97 Xantia MK1 V6 Exclusive in Mauritius Blue - 205K - "Old V6" - A new life begins.....
'06 Picasso Exclusive 110 in Mediterranean Blue - 106K
'14 308cc 2.0HDi 163 Roland Garros in Pearlescent White - 7K
x 8417
I can't see yours Paul... Looks like I killed it. Sorry. Just upload it again and all will be good...
I see the cheap Xantia V6 exhausts are still available on the 'bay...
Do a search on 'Xantia V6 Exhaust' and three different suppliers come up...
Has anyone had any experience with any of the vendors?
Or shall I just take pot luck and choose one at random?
PavlosV6
I'll try a different one for a change :roll:
I see the cheap Xantia V6 exhausts are still available on the 'bay... Yep
Do a search on 'Xantia V6 Exhaust' and three different suppliers come up... Yep
Has anyone had any experience with any of the vendors? Nope
As long as it sounds nice 8-)
Paul
x 8417
I'm just thinking that £60 for a full system will be much cheaper than trying to find just a back box...
I guess they'll all sound OK... Mine is very blowy now...
Good to see you have your avatar back :)
Sent from my Lumia 900 using Tapatalk
KP
x 27
Unread post by KP »
Jim if you can get a good mid box and back box as the noise could change for the worse :(
Has yours still got an original CAT Jim?
x 8417
Yep, original big cat Will. In fact the present exhaust is a genuine one...
PavlosV6
Indeed. Then you'll have a good stash of centre boxes.
Paul
PavlosV6
Jim, the time on posts is one hour behind BST. My PC clock currently says 20:34.
Paul
KP
x 27
Unread post by KP »
Jim why not just patch it? Or is it the joints?
x 8417
It's on Zulu time ;) I'll check the server time setup tomorrow. I likely forget the BST bit when setting up the server. Sorry...
