Are all the Mk3 C5's Can Bus operated or is it just the Exclusive models?
I've noticed some strange issues with my headlights not turning on (in manual and sometimes auto modes too).
If I turn the car off with headlights left in Manual 'ON' position, when I restart car the lights do not come on without turning the control stick back to the 'OFF' position and then back to headlights 'ON'.
Is this a standard thing please?
Also, would the Can Bus system tell me if a DRL bulb had failed, as neither of mine seem to work (and I do have the software activated on the steering wheel parameter settings)??
Cheers.
C5 Mk3 Can Bus?
bigblackfalco
- x 11
C5 Mk3 Can Bus?
58 plate (2009) C5 Tourer 2.0 HDi VTR+
- x 3304
Re: C5 Mk3 Can Bus?
When I had a Peugeot Partner (company van), it would do the same thing. I think the relevant ECUs don't 'remember' where the stalks are last time the ignition was on. It didn't have DRLs though, so I cannot help with them.
DickieG
- Monaco's youngest playboy
- x 38
Re: C5 Mk3 Can Bus?
Have you tried a BSI reset?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
bigblackfalco
- x 11
Re: C5 Mk3 Can Bus?
I'm afraid I haven't even heard of that .... can I do it with a paperclip?DickieG wrote:Have you tried a BSI reset?
- x 3304
Re: C5 Mk3 Can Bus?
This is the reset routine for a C5;
http://www.frenchcarforum.co.uk/forum/v ... 11&t=40407" onclick="window.open(this.href);return false;
bigblackfalco
- x 11
Re: C5 Mk3 Can Bus?
Great thanks. Kinda like a defrag on a computer I'm guessing?Hell Razor5543 wrote:This is the reset routine for a C5;
- x 3304
Re: C5 Mk3 Can Bus?
Sort of. More like a full PC Shut Down, as opposed to Standby. From what I have read on the forum it clears down glitches very well, PROVIDED the battery is good. The C series Citroens have a lot of electronic systems, and are VERY finicky about batteries. However, if you have a fault (as opposed to a glitch) it probably won't clear, and will need a Lexia session to diagnose it.
bigblackfalco
- x 11
Re: C5 Mk3 Can Bus?
Ok does it work on the basis that the battery must be fully charged prior to disconnection, or when reconnected ( in which case I will remove and charge!)Hell Razor5543 wrote:Sort of. More like a full PC Shut Down, as opposed to Standby. From what I have read on the forum it clears down glitches very well, PROVIDED the battery is good. The C series Citroëns have a lot of electronic systems, and are VERY finicky about batteries. However, if you have a fault (as opposed to a glitch) it probably won't clear, and will need a Lexia session to diagnose it.
Onlinemyglaren
- x 5671
Re: C5 Mk3 Can Bus?
When reconnected. Otherwise you are wasting your time.
bigblackfalco
- x 11
Re: C5 Mk3 Can Bus?
Ok thanks. I shall report my findingsmyglaren wrote:When reconnected. Otherwise you are wasting your time.
