Peugeot 306 hdi missfire/hesitation
paulpope33
Re: Peugeot 306 hdi missfire/hesitation
Unread post by paulpope33 »
just been given to diagrammes of the breather system i just have to find what one is on my car what would be the best way to find out would i have to take the tank off the car
Northern_Mike
Sounds like it's the cap that's at fault from what you say. Just replace it.
You'll probably be able to see a little pipe inside the fuel filler pipe if you look inside. That'll be the tank breather. If the hole in the cap is blocked it creates a vacuum and can't such fuel through.
I had an Orion 1.6 years ago that did this. It actually sucked the tank out of shape so much that the gauge read 1/2 full when it was empty. I only learnt about the problem when I, you guessed it, ran out of fuel one night. I'd driven 250 miles or so much slower than my normal speed but was still surprised at how little fuel I'd used. Of course, with the tank being sucked in like someone sacking a plastic bottle, the sender from the gauge was resting on the bit that had been sucked in and I didn't really have half a tank left.
Sent from my SM-N9005 using Tapatalk
paulpope33
i cant see any hole in the cap
Northern_Mike
I've just taken a couple of pics of the breather arrangement on my C5 HDi. I'll upload a link later.. just off to work now.
paulpope33
thank you
paulpope33
what ive done for now is drilled an hole in the fuel cap so at least it can breath
x 1487
Caps are supposed to be sealed these days I think. If you post up the last 8 digits of the VIN, I can look up to see what breather arrangement is fitted. I'm a bit surprised that tank breather problems can give running issues on one of these with that socking great LP pump, and without triggering the EML, but there's a new one everyday!
paulpope33
I will post the last 8 tonight when i get in from work since drilling hole in the cap the car as been running perfect
Northern_Mike
Re: Re: Peugeot 306 hdi missfire/hesitation
RichardW wrote:Caps are supposed to be sealed these days I think.
They may well be but a 306 HDi isn't going to be that new is it? My C5 HDi certainly has a breather in the cap.
paulpope33
Why don't all cap's have breathers
paulpope33
RichardW wrote:Caps are supposed to be sealed these days I think. If you post up the last 8 digits of the VIN, I can look up to see what breather arrangement is fitted. I'm a bit surprised that tank breather problems can give running issues on one of these with that socking great LP pump, and without triggering the EML, but there's a new one everyday!
My last 8 numbers are 32911919
Northern_Mike
My C5 HDi has a cap like this. The little rectangle hole is the breather.
I gather these holes in the filler neck insert are something to do with the breather arrangement
paulpope33
mine dont look like that i take photo then upload
as you can see i have drilled an hole in the cap to let the tank breath
x 1487
Here you go:
breather:
Filling duct
Not clear where the breather is on yours Mike- but that hole in the cap looks like where the tether should be attached on the drawing in service.citroen..... 8-)
Northern_Mike
Maybe it should Richard :-) However, if I put my lips on the cap, I can certainly blow through it. Doesn't taste great mind you..
