dispatch doorlocks
mark1
- New User
dispatch doorlocks
Hi guys, i know theres lots of threads about dispatch doorlocks but i think this is a new one, mine is a 109000 mile 2007 dispatch 1.6.HDI. My problem is this, the remote key fob is in bad shape and doesn't appear to work, the key turns fine and locks only the front doors. The back door can also be locked with the key. My main problem is that neither of the side doors either lock or unlock. Don't want to buy a new key fob only to find that something else is screwed too (sounds likely). The guy i bought it off had been told a central locking motor had failed? and they were about fifty quid? Any ideas? Getting really fed up having to empty the van every night, cheers guys.
- x 3298
Re: dispatch doorlocks
It could be worth checking the wiring. I had a problem on my Xantia in that the OSR would not react to the central locking, but could be locked/unlocked from the button, while the NSR was deadlocked and non-responsive. I found failed wiring for both, and they now work properly.
- x 5679
Welcome Mark
I can't help with the details I'm afraid but have you looked on eBay for CL motors, far less expensive than the dealer.
The likes of GSF and AEP may well supply them too.
BX
- x 19
The problem on the sliding doors is almost certainly the contacts on the sliding doors You should see contact points on the rear of the B pillars and spring loaded pins on the front of the sliding door that mate with them. Usually just clean and lubricate but I would fear that if you are in the UK the springs might have rusted.
Richard_C
- (Donor 2026)
- x 238
I had a rusted spring in the contact cluster, as it happens for the electric window but the principle is the same. If you push each contact in with your finger and one doesn't spring out again, that's the problem. It's relatively easy to dismantle and clean it up. Just 2 screws hold the thing in, maybe torx don't recall.
I found a similar length spring but couldn't get the right diameter for the sliding contact, but a dome headed self tapping screw in the end gave me a fix which has lasted several months and shows no sign of failure.
I've not tried to buy the right spring but suspect that dealers will want to sell a whole cluster complete which might be expensive.
At the same time I put Vaseline around the rubber seal where the contacts slide through, on both sides to try and keep water out.
Richard_C
Richard_C
- (Donor 2026)
- x 238
Another thought
On my synergie if the door handles on the outside don't spring back to the resting/central position it sometimes fails to lock. A bit of spray lube around the pivots sorts it out, but it sound like yours is more serious than that.
And another other thought,
can you lock it by the good old fashioned method of pushing the buttons down inside?
Richard_C
