Peugeot 306 hdi missfire/hesitation
paulpope33
Unread post by paulpope33 »
Hi there iam new to the forum and i was woundering if anyone could help me,i have a peugeot 306 hdi is drives fine but ive been suffering a problem iam not sure if you would call it a missfire or hesitation when driving this happens all the time when the car is cold/hot
any help would be greatfull
thanks
x 1240
Re: Peugeot 306 hdi missfire/hesitation
Unread post by Peter.N. »
I would think the most likely cause is air in the fuel supply, unless the in tank pump is failing.
paulpope33
ive had a new pump in the tank how would i know if theres air in the fuel supply
x 1240
On the older engines the test was to fit a clear section of fuel pipe on the input to the pump, don't know if that is possible on the Hdi, it probably is but you will have to cut the existing pipe to do it.
Gibbo_Wirral
Unread post by Gibbo_Wirral »
What year is the 306? If its fairly modern then the Lexia equipment should be able to read live data and tell you what's wrong.
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
paulpope33
its a 1999
x 3296
Take a look on the following link to see if there are any members near you with a Lexia who can help;
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178" onclick="window.open(this.href);return false;
paulpope33
theres a couple of places near me what do they charge to run the tests
ive my car in my works garage and they have said its all clear theres no fault codes nothing
x 3296
It depends on the forum member. The best thing to do is to PM them and ask. When I asked CitroJim for help he asked for de-caff teabags, and I got him a box of PG Tips de-caff and a box of Twinings Earl Grey (also de-caff). He seemed happy with that, and we (well, he) sorted the problem with Gracie.
paulpope33
how will i get intouch how do i find the person
x 3296
Using the map, locate the members nearest you. Make an accurate note of their forum name (make sure to get the case correct, member names are case sensitive). Then look near the top of the webpage and you will see three tabs; User Control Panel, 0 new messages (unless somebody has sent you a message, then the number changes), and View your posts. Click on the messages tab. Then click on New PM. In the small box below the large 'Compose Message' type in the member name as it appeared in the map and click on the Add button. If you typed in the name correctly after a moment it will appear above and to the right of the box. Type in the other details as you would for a normal e-mail, and (once you are happy with the message) click on the Submit button below the message. It will then go into your Outbox. It will remain in the Outbox until the recipient has read it, and then it will be moved into the Sent box.
paulpope33
thank you
x 3296
You are welcome.
paulpope33
was reading a thread eles where about same problem iam having they said about taking the cap off the fuel tank so i thought i would give it ago so i took mine off this morning and drove to work without any problems the car ran perfect without any missfire/hesitation iam guessing its a problem with the fuel cap being on the tank could be starving the car of fuel
x 3296
There normally is some form of breather pipe (or the fuel cap has a breather hole through it) in the fuel tank to allow air in as the fuel is used. I would find out what breather system your car uses, and clear the blockage.
