98 sx 2.1 TD, wire cut?
foeism
Unread post by foeism »
Hi
Forgot to post earlier; I noticed this wire on the n/s front wheel has been cut. Any ideas what it could/was for?
sparksie
x 33
Re: 98 sx 2.1 TD, wire cut?
Unread post by sparksie »
Hi
Zoomed in just a tad too close to show us where the cable goes at the hub end.
However, assuming there are no warnings showing, my guess would be brake lining wear indicator.
If you back off just a smidgeon, so we can see the caliper and hub carrier, I'll know for certain.
Of course, someone with specific SX knowledge will recognise it from the existing pic and post the answer while you're out taking another shot!
Sparksie
2000 Xantia 1.9TurboD
electronmirror
x 31
Unread post by electronmirror »
It is indeed the brake pad wear warning light wiring. It does break at that point after years of flexing.....
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (135,980miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
