drive hdi citroens but being offered a renault dci?
This is the Forum for all your Renault Technical Questions, Problems or Advice.
fotobright
Unread post by fotobright »
Hi,
I'm looking to replace my citroen xsara estate 2.0L HDI. Have been looking for a C5 but not much up here in central scotland.
I've just seen a 2004 Laguna estate 1.9DCI @ 66,000 but dont know anything about the reliability and running cost of the DCI engine. The HDI engine is one I know, should I consider the DCI or stick to what I know in terms of DIY repair costs?
ps just noticed the ad says The ABS warning light is on and also the service light. I have access to a Lexia to check the issue, may or may not be a big problem?
Peugoet 308 SW HDI 1.6 Live*
Peugoet 207 SW Hdi 1.6
C5 2.2L HDi 16v estate (01)
Xsara Hdi 90 estate
Xantia 1.9TD estate, (veg oil)
Zx 1.9TD hatchback
Zx 1.9D hatchback
fotobright
Re: drive hdi Citroëns but being offered a renault dci?
Actually i've not idea whether Lexia works on A renault. Looking around thought at some of the general issues with early Laguna's night give those a miss and stick to a 2.0 HDI :)
Xsara Hdi 90 estate
Zx 1.9TD hatchback
Zx 1.9D hatchback
x 5671
There are a couple of Lagunas been offered in the "For Sale & Wanted" forum that may give a reasonable idea of what to expect.
x 3304
The Lexia won't work on Renaults. I believe you want a Clip.
Northern_Mike
Re: Re:
superloopy wrote:Will a Lexia work on a Renault??
No it needs Renault Clip.
I'm just a grumpy Northern git.
bxzx16v
x 35
Unread post by bxzx16v »
We had a laguna 2 with the 1.9dci and never had any problems in 5 1/2 yrs but I've known them to be problematic. A laguna 2 with the 2.0 dci might be a better choice. Imo they drive alot nicer than the equivalent C5 [-X. Or if you can stretch your budget laguna 3's are fantastic value.
Mark
steelcityuk
Unread post by steelcityuk »
The dCi isn't what you'd call tolerant, I've had 3 dCi, all fickle. How about a Picasso? Has to be Clip, other interfaces can be miles off.
Steve.
not applicable
fotobright
Resolved the dCi issue by buying a C5 2.2L yesterday.
Xsara Hdi 90 estate
Zx 1.9TD hatchback
Zx 1.9D hatchback
steelcityuk
Did you research the 2.2 first?
not applicable
fotobright
I know where this is going. Did I researched? Yes and no, but lets leave it there till we've inspected with the lexia properly ha!
steelcityuk wrote:Did you research the 2.2 first?
Xsara Hdi 90 estate
Zx 1.9TD hatchback
Zx 1.9D hatchback
